really i need help
really i need help
abdulellah.alattab
Message 1 of 71
really i need help
abdulellah.alattab
Please i need lisp to do this task
Old topic link
https://forums.autodesk.com/tUntitled-13-2.png⁸5/visual-lisp-autolisp-and-general/call-for-help-cranking-polyline/td-p/13362612
Replies (70)
Message 2 of 71
LDShaw
Hello
  1. Page not found on your link.
  2. Are your "formula's" the same each time. (L1-L4, the F's and the H's)
  3. Can this be broken up into smaller steps as we try to create what you need?
Message 3 of 71
abdulellah.alattab
Sir, do what you think is appropriate. Someone really frustrated me, and we are in dire need of this Lisp to complete pending work, if you mean ،
We often do this task with these parameters, we find the value of shrinkage and the value of length by dividing another length by a certain parameter, you can make a certain development,
Please See again in attached photo
Message 4 of 71
abdulellah.alattab
I will depend on you, there is another person who helped me but unfortunately he is not here since then ،
All my appreciation to him
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/call-for-help-cranking-polyline/td-p...
Message 5 of 71
abdulellah.alattab
A, B, L1, L2, F1 F2, H = any real number, I was expelled by the keyboard, RB, I will crush you, my stomach, you point, I am not a model plumber
Message 6 of 71
LDShaw
Don't depend on me. Your other thread is fairly complete and has more work in it than I can devote to you.
I suggest you reopen that thread and work from there. People are far more likely to edit a lisp than to write you another one.
Message 7 of 71
abdulellah.alattab
Can you participate in it?
Message 8 of 71
Moshe-A
@abdulellah.alattab  hi,
In the coming days i will publish here something you could start working with 😀
could you post an image how the bar will look like in final, including your preferred layers,
colors and dimensions.
edit: also how the geometric will end (look on the other side)
Moshe
Message 9 of 71
abdulellah.alattab
Really, you can imagine how much we will be grateful to you
Message 10 of 71
Sea-Haven
Message 11 of 71
Moshe-A
After 10 days of working (a very big lisp), here is what i got  (i am sure you will like it 😀)
attached is reinforce.zip file, release its content to a folder and load reinforce.vlx lisp file.
command: bar1
please, read these instruction first for better under standing it:
As you can see in the picture, the dialog is divide into 3: Main field L1, Left field L2 & Right field L3
at load, Left & Right are disabled cause you need to start by selecting the 2 main axes lines (main field)
the axes lines must be straight vertical lines. to define the field beside, enable the switch under (toggle button)
bellow 3 edit boxes: Length1, Length2 & length3. Length1 will be auto filled after you select the 2 main axes and it will stay grey always.
Length2 & Length3 edit boxes will be auto filled if you select the Left/Right axis or if you do not have side axis you can specify the distance of the
field in Length2 & Length3. if the bar does does extend to sides you can disable the switches (for not using side fields)
bellow 3 edit boxes: Retreat Ratio 1, Retreat Ratio2 & Retreat Ratio3 (you got the idea what is for 😀)
you can enter a real numeric value like 0.25 or 0.3333 or 1/4 , 1/3. these fields is restricted to 0.2 (1/5) min up to 0.4 (1/2.5) max.
below 2 edit boxed: Bend depth (bar height) & Bend angle (restricted to 0-90)
bellow that comes Properties where you can select a layer and color for the bar and it's dimensions.
in dimscale edit box you can specify the dimension scale factor for the dimensions (the base text height is 0.2)
so 50 is reasonable value for a drawing plotted at 1:50.
finally pick Draw Bar button to specify the location point of bar.
Now i am sure we will enter to corrections phase, take your time to process this and gather all your requests for corrections
and i will make the effort to do it as fast as i can (in my very limited free time 😀)
p.s: work only in WCS.
enjoy
Moshe
Message 12 of 71
Moshe-A
Anybody seen @abdulellah.alattab  around?
Message 13 of 71
Sea-Haven
Yes gone quiet I posted similar answer using a dcl.
Message 14 of 71
Moshe-A
@Sea-Haven ,
pity 😩 such a beautiful solution would go to orphanhood?!
@abdulellah.alattab  wakeup
Message 15 of 71
abdulellah.alattab
Sorry sir, I was busy with work and felt frustrated and embarrassed by the repeated request.
Message 16 of 71
abdulellah.alattab
Whatever you have done, it is worthy of thanks for your concern.
Message 17 of 71
Moshe-A
@abdulellah.alattab ,
pppppppppppppppppp...a you took a month off 😩
did you give it a try? works?
Message 18 of 71
abdulellah.alattab
Is it possible to add a button that prevents writing dimensions, and is it possible to rotate the rod during entry, and instead of the minimum of 1/5 and the maximum, is it possible to have more freedom so that we can use it for more purposes?
Message 19 of 71
abdulellah.alattab
Yes, I tried it. Thank you for making the input window integrated into one file.
Message 20 of 71
abdulellah.alattab
Addtional to pick axes can you add option , select two points
