Read-line before or after a comma
Jonathan3891
Advisor Advisor
Message 1 of 10
Jonathan3891
Is it possible to read a line in a text file before or after a comma?
For example:
Line 1 will have: TEST1,TOS %%script(Q = (%ObjectTopLevel): If Q>0 then appendstring ("+" & (FormatNumber(Q,3))) else appendstring (FormatNumber(Q,3)))
But the list box will only show: TOS %%script(Q = (%ObjectTopLevel): If Q>0 then appendstring ("+" & (FormatNumber(Q,3))) else appendstring (FormatNumber(Q,3)))
My current code segment to read a file:
  (setq LC nil)
  (setq OpenFile (open (findfile "LabelContent.cfg")"R"))
  (while (setq line (read-line OpenFile))
    (setq LC (cons line LC))
    );while
  (setq LC (reverse LC))
  (close OpenFile)
  (dcl-ListBox-AddList LabelContent/Form1/ListBox1 LC)
Jonathan Norton
Blog | Linkedin
Replies (9)
Message 2 of 10
ВeekeeCZ
Why? Just split it afterward.
Message 3 of 10
Jonathan3891
I'm building a dcl that contains vbscript's for Advance Steel.
The text before the comment is meant to be a description of the script.
I do not know how to split it afterward.
Jonathan Norton
Blog | Linkedin
Message 4 of 10
ВeekeeCZ
Seems too simple, I must be missing something...
(setq lc2 (mapcar '(lambda (x) (substr x (+ 2 (vl-string-search "," x)))) lc))
(dcl-ListBox-AddList LabelContent/Form1/ListBox1 LC2)
Message 5 of 10
Jonathan3891
Thank you @ВeekeeCZ. I'm only a novice code writer.
I'm sure it's simple, but how do I read only the string before the comma?
Jonathan Norton
Blog | Linkedin
Message 6 of 10
ВeekeeCZ
(setq lc1 (mapcar '(lambda (x) (substr x 1 (vl-string-search "," x))) lc))
Message 7 of 10
Jonathan3891
Thank you @ВeekeeCZ!
Jonathan Norton
Blog | Linkedin
Message 8 of 10
ВeekeeCZ
BTW that posted code search for 1st comma in the line. But you have multiple commas there -- so it presumes that you have this comment at the beginning of each line (if there are more lines in the file).
Message 9 of 10
Jonathan3891
The first comma is all I needed. The rest is part of the VBScript.
Jonathan Norton
Blog | Linkedin
Message 10 of 10
Jonathan3891
Here is what it looks like so far.
Jonathan Norton
Blog | Linkedin
