Input the current user's username into a file path
cchiles
cchiles
Hi, I have what I believe will be a simple question - or not:
If I set the following first:
(setq user (getvar 'loginname))
How do I go about inputting "user" into the following path:
(setvar "trustedpaths" "C:\\<HERE>\\OneDrive;
Or if there is a simpler way to input the current windows login username into a support path file path I would love to know it.
Thanks very much,
Chris
Thanks in advance!
-Chris
Sea-Haven
You can add paths on the fly
(setq *files*  (vla-get-files  (vla-get-preferences (vlax-get-Acad-object))))
(setq paths (vla-get-SupportPath *files*))
(vla-put-SupportPath *files* (strcat user ";" paths))
(setq oldtrust (getvar 'trustedpaths))
(setvar 'trustedpaths (strcat oldtrust ";" user))
paullimapa
and to add to @Sea-Haven 's solution you should check to see if user is already there in the trustedpaths before adding:
(if (not (wcmatch (getvar"trustedpaths") (strcat"*C:\\" user "\\OneDrive*")))
 (setvar 'trustedpaths (strcat oldtrust ";C:\\" user "\\OneDrive"))
Paul Li
IT Specialist
@The Office
john.uhden
@paullimapa ,
Be careful there, Paulli.
wcmatch treats case as sensitive.
(setq this "A;B;OneDrive;C" that "*onedrive*")
(wcmatch this that) returns nil.
But
(wcmatch (strcase this) (strcase that)) returns T
John F. Uhden
paullimapa
Yes @john.uhden ... good catch on that. You are absolutely correct
Paul Li
IT Specialist
@The Office
