Read 'ElementTypes' from Revit to CAD
I have exported DWG file from Revit and I opened it in CAD.
I'm trying to make a lisp in CAD that change a layer color to match the CAD exporting settings in Revit.
I've used the XData in the layer's lines to get the Type ID from it.
Now I want to get this type color from Revit to apply it to the CAD Layer.
I think if I can read all BuiltinCategories in Revit, I can do that.
How can I do that, although I can't use RevitAPI with CAD?
Maybe a better option would be to setup a standard for exporting from Revit DWG files so that the Colors of Layers are set properly.  You can read up on this on the following link:
https://knowledge.autodesk.com/support/revit-products/learn-explore/caas/CloudHelp/cloudhelp/2015/EN...
Area Object Link | Attribute Modifier | Dwg Setup | Feet-Inch Calculator
Layer Apps | List on Steroids | VP Zoom Scales | Exchange App Store
