Hello everybody,
I'm changing an excisting P&ID. In this P&ID almost every line isn't perfectly horizontal or vertical.
What is the fastest way to change the delta X from every vertical line or the delta Y from every horizontal line into 0.
Is it possible (by using al lisp) to select only the horizontal OR the vertical lines with a delta value of <1 for changing the different delta values into 0?
