Read csv file then plot to PDF
kleber3NH6F
kleber3NH6F
Hi all,  my lisp knowledge is very limited so I was hoping someone could help mw with this.  I have a lisp which I copied from a Autodesk forum (https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/export-to-pdf-lisp-routine/td-p/5704... and tweaked a little to suit my needs. It basically plot all layout tabs to PDF (with revision letter at the end of the pdf name). It works just fine.
Now, what I want it to do is to instead of printing all layouts, read a csv file "title_block.csv" and only plot to PDF layouts named in that csv file.
I used Lee Mac's code/functions to read a csv file in the same folder as the .dwg (title_block.csv) which has only one set of data in column 1. (layout to be ploted, eg: row1 "Layout" row2 "200" row3 "300"). However it doesn't send the command "_.-PLOT" and I get erros like: Unknown command "PC3".  Press F1 for help. Unknown command "00 X 297.00 MM)".  Press F1 for help.... etc
Would someone be able to tell me what is wrong with it?
#(defun c:PDF ( / data file )
  (command "MODEL")
  (setq cmd (getvar 'cmdecho)) (setvar 'cmdecho 0)
  ; check that pdf directory exists
	(setq dwgpre (strcat (getvar "dwgprefix") "PDF"))
  ;if doesn't exist create one
	(if (= (vl-file-directory-p dwgpre) nil)
		(vl-mkdir dwgpre)
	(setq pdfname (strcat (vl-filename-base (getvar "dwgname"))))
    (if
        (and
            (setq file (findfile "title_block.csv"))
	    (setq data (cdr(LM:readcsv file)))
        (progn
            ;(princ "\n(")
            (foreach layout data
	        ;(princ "\n    ")  (prin1 layout)
		;(princ "\n)")
	      	(command
	"_.-PLOT"
	"Y"									;Detailed plot configuration? [yes/no]
	Layout									;Enter Layout name or [?],layout1:
	"Dwg To PDF.pc3"							;Enter an output device name
	"ISO full bleed A3 (420.00 x 297.00 MM)"				;Enter paper size
	"M"									;Paper units: "M" for mm
	"L"									;Enter drawing orientation: "L" for Landscaping
	"N"									;Upside down? "N"
	"E"									;"E" for extents
	"1:2"									;Plot scale: Custom "1:2"
	"C"									;Counter "c"
	"Y"									;Plot Style? "y"
	"A3.ctb"								;Enter plot style: "A3.ctb"
	"Y"									;Plot line  weights?
	"N"									;plot line scaling?
	"N"									;Paper space first?
	"N"									;Hide?
	(strcat dwgpre "\\" pdfname "-" (getvar "ctab") ".pdf")			;Directory to save
	"N"									;save changes to page setup?
	"Y"									;proceed with plot?
		    );command
	      	(prompt "\nSuccessfully Plot.....")
		;(princ "\n)")
        );progn
    (princ)
(princ)
;; Read CSV  -  Lee Mac
;; Parses a CSV file into a matrix list of cell values.
;; csv - [str] filename of CSV file to read
(defun LM:readcsv ( csv / des lst sep str )
    (if (setq des (open csv "r"))
        (progn
            (setq sep (cond ((vl-registry-read "HKEY_CURRENT_USER\\Control Panel\\International" "sList")) (",")))
            (while (setq str (read-line des))
                (setq lst (cons (LM:csv->lst str sep 0) lst))
            (close des)
    (reverse lst)
;; CSV -> List  -  Lee Mac
;; Parses a line from a CSV file into a list of cell values.
;; str - [str] string read from CSV file
;; sep - [str] CSV separator token
;; pos - [int] initial position index (always zero)
(defun LM:csv->lst ( str sep pos / s )
    (cond
        (   (not (setq pos (vl-string-search sep str pos)))
            (if (wcmatch str "\"*\"")
                (list (LM:csv-replacequotes (substr str 2 (- (strlen str) 2))))
                (list str)
        (   (or (wcmatch (setq s (substr str 1 pos)) "\"*[~\"]")
                (and (wcmatch s "~*[~\"]*") (= 1 (logand 1 pos)))
            (LM:csv->lst str sep (+ pos 2))
        (   (wcmatch s "\"*\"")
            (cons
                (LM:csv-replacequotes (substr str 2 (- pos 2)))
                (LM:csv->lst (substr str (+ pos 2)) sep 0)
        (   (cons s (LM:csv->lst (substr str (+ pos 2)) sep 0)))
(defun LM:csv-replacequotes ( str / pos )
    (setq pos 0)
    (while (setq pos (vl-string-search  "\"\"" str pos))
        (setq str (vl-string-subst "\"" "\"\"" str pos)
              pos (1+ pos)
    str
ВeekeeCZ
Maybe try to replace:
with
(strcat dwgpre "\\" pdfname "-" Layout ".pdf")
If it fails, turn the echo on and copy-past all the command-line listing.
kleber3NH6F
Hi BeeKeeCZ,
Thanks for replying. I have actually found the answer from another forum. I need to change the line:
(foreach layout (list data)
to:
(foreach layout (mapcar 'car data)
That did the trick!
Thanks anyway
