Reactor Guru!!
Reactor Guru!!
sam_safinia
Reactor Guru!!
sam_safinia
This lisp routine was supposed to insert dynamic blocks with more flexibility of selecting and parameter data entry... but it gets stuck!
By running the lisp it uses dynamic input selection to select one of the blocks then it's asking dynamic block parameters to define block then insert it (by using reactor). The problem is it doesn't terminate first block insertion and looping back to db parameters and then it exits the routine. Another issue is it doesn't run for the second time and says "Unknown command".
any suggestion?
sam_safinia
Resolved. By BeeKeeCZ
