RE) LISP Get entities layer list within blocks and change layer of blocks
darkfprh
darkfprh
Hi
I need a lisp that checks all block's inside entities' layer.
and It has more than 2 layers, change block's layer to "0".
help me plz.
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/lisp-get-entities-layer-list-within-...
vinodkl
Hi @darkfprh
Have you tried the FIXBLOCK lisp? See attached.
Also, it would be great if you would stick to a single post instead of creating a new thread. It would create more confusion than solving your problem as people in the forum will ignore to answer the thread if they find it repetitive🙂
ವಿನೋದ್ ಕೆ ಎಲ್( System Design Engineer)
Likes is much appreciated if the information I have shared is helpful to you and/or others.
Please mark "Accept as Solution" if my reply resolves the issue or answers your question, to help others in the community.
Kent1Cooper
@vinodkl wrote:
Have you tried the FIXBLOCK lisp? .... stick to a single post instead of creating a new thread. ....
I don't think FIXBLOCK is what they're after.  It looks like it puts the objects within Block definitions on Layer 0 [and color ByLayer], but they're not talking about changing the Layer of ingredients within Blocks.  They want to change the Layer of Block insertions whose Block-definition ingredients include things on more than 2 Layers.
[I agree about double posting, but I think the intent is much more clearly described in this one.]
@darkfprh , would you want to do this to dynamic Blocks as well as "ordinary" Blocks?  It makes a difference in how Blocks that need their Layer changed are found.
Kent Cooper, AIA
darkfprh
That's it! it is absolutely I want.
And don't need to change dynamic blocks.
thank you.
Kent1Cooper
This seems to do that, in very limited testing:
(defun C:M2LB0 ; = More-than-2-Layer Blocks to layer 0
  (/ blk ent blkname layers ss)
  (while (setq blk (tblnext "block" (not blk))); step through Block table
    (setq
      ent (tblobjname "block" (setq blkname (cdr (assoc 2 blk))))
      layers nil ; clear from previous Block if applicable
    ); setq
    (while
      (and
        (< (length layers) 3); hasn't yet exceeded 2 [or doesn't exist yet]
        (setq ent (entnext ent)); step through Block ingredients
      ); and
      (if (not (member (setq lay (cdr (assoc 8 (entget ent)))) layers)); Layer name not in list yet
        (setq layers (cons lay layers)); add it
      ); if
    ); while -- stepping through Block ingredients
    (if (> (length layers) 2); Block has ingredients on more than 2 layers
      (if (setq ss (ssget "_X" (list (cons 2 blkname)))); find all insertions [if any]
        (repeat (setq n (sslength ss)); then
          (vla-put-Layer (vlax-ename->vla-object (ssname ss (setq n (1- n)))) "0")
        ); repeat
      ); if [insertions exist]
    ); if [too many Layers in Block definition]
  ); while -- stepping through Block table
  (princ)
); defun
(vl-load-com)
(prompt "\nType M2LB0 to change More-than-2-Layer Blocks to layer 0.")
It doesn't account for the possibility that some such Blocks may be inserted on locked Layers.  Should it?
Kent Cooper, AIA
darkfprh
Thank you so much! It works well. really thank you!!!
but I want to change block's layer "in block". (1 level inside)
so I will study and modify this lisp.
If you don't mind can you help me more?
