RE-ADD FRAGMENT
RE-ADD FRAGMENT
rolisonfelipe
Message 1 of 8
RE-ADD FRAGMENT
rolisonfelipe
Hello, Good morning!
Have as re-add, this fragment, because I discovered that it is possible to shift the text from the project axis up or down, but when add that fragment, and add the variables give error in executing in the CAD.
If possible add a variable to perform this offset, it would be perfect.
ex:(setq OFFSET (getdist (getvar "VIEWCTR") (strcat "\n ENTER VALOR OFFSERT: <" (rtos (getvar "offset)) ">: ")))
Certain of his understanding, and my sincere appreciation
(defun c:ROAD ( / js n AcDoc Space ll ur t_width nw_obj att_pt t_ang m_pt nw_objename obj pr nb typ_obj
   oldim oldlay a_base a_dir pt_start pt_end pt_cen
  rad alpha pt_vtx dist_start dist_end seg_len seg_bulge)
 (defun TGTEXTO (ins_txt value_str a / nw_obj)
    (setq nw_obj (vla-addMtext Space (vlax-3d-point (trans ins_txt 1 0)) 0.0 value_str))
 ;;;      (setq nw_obj (vla-addmtext Space (vlax-3d-point m_pt) 0.0 value_str))
 ;;;      (vla-getboundingbox nw_obj 'll 'ur)
 ;;;      (setq ll (vlax-safearray->list ll)
 ;;;            ur (vlax-safearray->list ur)
 ;;;            t_width (+ (* (distance ll ur) (cos (angle ll ur))) 5.0)
 ;;;      );end_setq
 ;;;      (if (>= t_width seg_len)
 ;;;        (setq att_pt 5
 ;;;              t_width seg_len
 ;;;        );end_setq
 ;;;        (setq att_pt 8
 ;;;  m_pt (polar m_pt (+ t_ang (/ pi 2)) (* (getvar 'TEXTSIZE) 10)) <----This is the value that controls the OFFSET of the text
 ;;;        );end_setq
 ;;;      );end_if
      (mapcar '(lambda (pr val) (vlax-put nw_obj pr val))
      (list 'AttachmentPoint 'Height 'DrawingDirection 'InsertionPoint 'StyleName 'Layer 'Rotation)
      (list 5 (getvar "TEXTSIZE") 5 ins_txt "TGDdim" "TGCOTA" (if (and (< a (* pi 0.5)) (> a (* pi 1.5))) (setq a (+ a pi)) a)) )
    (entmod
      (append
      (vl-remove-if
        (function
          (lambda (x)
            (or (member (car x) '(90 63 421 45))
              (< 419 (car x) 440))))
        (entget (entlast)))
      (list
        '(90 . 1)
        '(63 . 41)
        '(421 . 16770196)
        '(45 . 1.5) ) ) )
    (entupd (entlast)))
  (princ "\nSelect polylines/Arc : ")
  (setq
    js
    (ssget
      '((-4 . "<OR")
        (-4 . "<AND")
          (0 . "POLYLINE")
          (-4 . "<NOT")
            (-4 . "&") (70 . 126)
          (-4 . "NOT>")
        (-4 . "AND>")
        (0 . "LWPOLYLINE,ARC")
        (-4 . "OR>"))
    n -1
  (cond
    (js
      (setq
        AcDoc (vla-get-ActiveDocument (vlax-get-acad-object))
        Space
          (if (= 1 (getvar "CVPORT"))
            (vla-get-PaperSpace AcDoc)
            (vla-get-ModelSpace AcDoc) ) nb 0 )
      (cond
        ((null (tblsearch "LAYER" "TGCOTA"))
          (vlax-put (vla-add (vla-get-layers AcDoc) "TGCOTA") 'Color 7) ) )
      (cond
        ((null (tblsearch "STYLE" "TGDdim"))
          (setq nw_style (vla-add (vla-get-textstyles AcDoc) "TGDdim")
                nw_font (strcat (getenv "systemroot") "\\Fonts\\Arial.ttf") )
          (mapcar '(lambda (pr val) (vlax-put-property nw_style pr val))
               (list 'FontFile 'Height 'ObliqueAngle 'Width 'TextGenerationFlag)
               (list nw_font 0.0 (/ (* 0.0 pi) 180) 1.0 0.0) ) ) )
      (setq
  oldim   (getvar "dimzin")
  oldlay   (getvar "clayer")
  a_base   (getvar "ANGBASE")
  a_dir   (getvar "ANGDIR")
      (setvar "dimzin" 0) (setvar "clayer" "TGCOTA")
      (setvar "ANGBASE" 0) (setvar "ANGDIR" 0)
      (initget 6)
      (setq h_t (getdist (getvar "VIEWCTR") (strcat "\nTaille du texte <" (rtos (getvar "textsize")) ">: ")))
      (if (null h_t) (setq h_t (getvar "textsize")) (setvar "textsize" h_t))
      (repeat (sslength js)
        (setq
          ename (ssname js (setq n (1+ n)))
          obj (vlax-ename->vla-object ename) pr -1 nb 0 )
        (setq typ_obj (vla-get-ObjectName obj))
        (if (eq typ_obj "AcDbArc")
          (progn
            (setq
              pt_start   (vlax-get obj 'StartPoint)
              pt_end   (vlax-get obj 'EndPoint)
              pt_cen   (vlax-get obj 'Center)
              rad   (vlax-get obj 'Radius)
              alpha   (* (vlax-get obj 'TotalAngle) 0.5)
              seg_len   (vlax-get obj 'ArcLength)
              pt_vtx   (polar pt_cen (+ (vlax-get obj 'StartAngle) alpha) (+ rad (* rad (1- (/ 1 (cos alpha))))))
              nb   (1+ nb))
            (TGTEXTO
              (mapcar '* (mapcar '+ pt_start pt_end) '(0.5 0.5 0.5))
              (strcat
                "{\\fArial Narrow|b0|i0|c0|p34;"
                "CURVE N+"  (itoa nb)
                "\\P AC:"  (angtos (- pi (* 2 alpha)) 0 4)<---- Because at that point the angle was not degree minutes and seconds
                "%%ddm\\P TG:"  (rtos (distance pt_start pt_vtx) 2 3)
                "m\\P RAY:"  (rtos rad 2 3)
                "m\\P DISTANCE:" (rtos seg_len 2 3) "m" "}" ) (angle pt_start pt_end) ) )
          (repeat (fix (vlax-curve-getEndParam obj))
            (setq
  dist_start  (vlax-curve-GetDistAtParam obj (setq pr (1+ pr)))
  dist_end  (vlax-curve-GetDistAtParam obj (1+ pr))
  pt_start    (vlax-curve-GetPointAtParam obj pr)
  pt_end   (vlax-curve-GetPointAtParam obj (1+ pr))
  seg_len  (- dist_end dist_start)
  seg_bulge  (vla-GetBulge obj pr) )
            (if (not (zerop seg_bulge))
              (progn
                (setq
  rad   (/ seg_len (* 4.0 (atan seg_bulge)))
  alpha   (+ (angle pt_start pt_end) (- (* pi 0.5) (* 2.0 (atan seg_bulge))))
  pt_cen   (polar pt_start alpha rad)
  pt_vtx   (polar pt_start (- alpha (* pi 0.5)) (* rad (/ (sin (* 2.0 (atan seg_bulge))) (cos (* 2.0 (atan seg_bulge))))))
  alpha   (if (< (* 2.0 (atan seg_bulge)) 0) (- pi (* 2.0 (atan seg_bulge))) (* 2.0 (atan seg_bulge)))
  nb    (1+ nb))
                (TGTEXTO
                  (vlax-curve-GetPointAtParam obj (+ 0.5 pr))
                  (strcat
  "CURVE "  (itoa nb)
              (TGTEXTO
                (strcat
  "DISTANCE "   (rtos seg_len 2 3)
  "m\\P Az:"   (vl-string-subst "%%d" "d" (angtos (+ (angle pt_start pt_end) (- (* pi 0.5) (* 2.0 (atan seg_bulge)))) 1 4)) "}"
                )<---- And at this point of azimuth on Angulo is correct, in degree minutes and second!!!!??
      (setvar "dimzin" oldim) (setvar "clayer" oldlay)
      (setvar "ANGBASE" a_base) (setvar "ANGDIR" a_dir)
  (prin1)
Replies (7)
Message 2 of 8
Moshe-A
@rolisonfelipe  hi,
you can replace the above code with this call to the following function:
usage:
(setq offset (askoffset (getvar "viewctr") "Enter volar offset" 10))
moshe
(defun askoffset (base msg def / ask)
 (initget (+ 2 4)) ; reject zero + negative values
 (setq ask (getdist base (strcat "\n" msg ": <" (rtos def 2) ">: "))
 (if (not ask)
  (setq ask def)
  (setq def ask)
 ); if
); askoffset
Message 3 of 8
rolisonfelipe
When the fragment that is with the    - ; -   You have adjusted this will be possible
Message 4 of 8
Moshe-A
in AutoLISP terms/format when a line starts with a semicolon ';' character? then all characters coming after are considered comment and not evaluate as code.
when you want a comment to spreads for few lines, start it with ';|' and close it with '|;' for example:
;|  this start a multi-line comment
first       comment line
second  comment line
third      comment line
next will close multi-line comment
Message 5 of 8
rolisonfelipe
I put the; In front of the part that would like it to be reincorporated, and add; Where the error, because if someone is to test what this right will run smoothly, but as to the notation; Is the same usoal, but add the comment with | I got it right now... Thank you...
 ;;; |     (setq nw_obj (vla-addmtext Space (vlax-3d-point m_pt) 0.0 value_str))
 ;;; |     (vla-getboundingbox nw_obj 'll 'ur)
 ;;; |      (setq ll (vlax-safearray->list ll)
 ;;; |     ur (vlax-safearray->list ur)
 ;;;|            t_width (+ (* (distance ll ur) (cos (angle ll ur))) 5.0)
 ;;; |     );end_setq
 ;;; |     (if (>= t_width seg_len)
 ;;; |       (setq att_pt 5
 ;;; |             t_width seg_len
 ;;; |       );end_setq
 ;;; |       (setq att_pt 8
 ;;; |  m_pt (polar m_pt (+ t_ang (/ pi 2)) (* (getvar 'TEXTSIZE) 10)) <----This is the value that controls the OFFSET of the text
 ;;;|        );end_setq
 ;;;|      );end_if
    (entmod
      (append
      (vl-remove-if
        (function
          (lambda (x)
        (entget (entlast)))
      (list
        '(90 . 1)
        '(63 . 41)
        '(421 . 16770196)
        '(45 . 1.5) ) ) )
    (entupd (entlast)))
  (setq
    js
    (ssget
      '((-4 . "<OR")
        (-4 . "<AND")
          (0 . "POLYLINE")
          (-4 . "<NOT")
          (-4 . "NOT>")
        (-4 . "AND>")
        (-4 . "OR>"))
    n -1
  (cond
    (js
      (setq
        Space
      (cond
      (cond
      (setq
      (initget 6)
        (setq
          (progn
            (setq
              nb   (1+ nb))
            (TGTEXTO
              (strcat
            (setq
              (progn
                (setq
  nb    (1+ nb))
                (TGTEXTO
                  (strcat
  "CURVE "  (itoa nb)
              (TGTEXTO
                (strcat
  (prin1)
Message 6 of 8
Kent1Cooper
That needs to use the right System Variable name, and be either "offsetdist" [double-quotes both before and after] or 'offsetdist [apostrophe before only].
Kent Cooper, AIA
Message 7 of 8
rolisonfelipe
HI , @Kent1Cooper
Good afternoon!!!!!!!!
It is true, this detail has passed without being noticed, in the next I will observe in more detail.
 I ADD the fragment that had proposed with the appropriate observations made by you, but the place where Varivel must act is not implemented in the scope of Lisp and when I put it, the general error.
    (setq nw_obj (vla-addMtext Space (vlax-3d-point (trans ins_txt 1 0)) 0.0 value_str)) I would also like to remove this component  "trans ", because it generates a fictional alignment that has time of error.
);end_setq
(setq att_pt 5
 t_width seg_len
);end_setq
 (setq att_pt 8
 m_pt (polar m_pt (+ t_ang (/ pi 2)) (* (getvar 'TEXTSIZE) 10)) <<<<<<<<<<<The offset variable has to stay at the location of Number 10,
);end_setq   But all that part in Red has to go back to the body of programming,
the text to exit the axis line and leaves the center of
)end_if      the project free If you can help me re-insert, I'll be very grateful.
    (entmod
      (append
      (vl-remove-if
        (function
          (lambda (x)
        (entget (entlast)))
      (list
        '(90 . 1)
        '(63 . 41)
        '(421 . 16770196)
        '(45 . 1.5) ) ) )
    (entupd (entlast)))
  (setq
    js
    (ssget
      '((-4 . "<OR")
        (-4 . "<AND")
          (0 . "POLYLINE")
          (-4 . "<NOT")
          (-4 . "NOT>")
        (-4 . "AND>")
        (-4 . "OR>"))
    n -1
  (cond
    (js
      (setq
        Space
      (cond
      (cond
      (setq
      (initget 6)
      (setq offset (getdist (getvar "VIEWCTR") (strcat "\nTaille du offset <" (rtos (getvar "offset")) ">: ")))    ;<<<-Add
        (setq
          (progn
            (setq
              nb   (1+ nb))
            (TGTEXTO
              (strcat
                "\\P AC:"  (angtos (- pi (* 2 alpha)) 0 4)<---- Why at that point the angle was not degree minutes and seconds?
                "%%dd\\P TG:"  (rtos (distance pt_start pt_vtx) 2 3)
            (setq
              (progn
                (setq
  nb    (1+ nb))
                (TGTEXTO
                  (strcat
  "CURVE "  (itoa nb)
              (TGTEXTO
                (strcat
  (prin1)
Message 8 of 8
rolisonfelipe
01 I managed to make this correction
 "\\P AC:"  (angtos (- pi (* 2 alpha)) 0 4) ;<---- Because at that point the angle was not degree minutes and seconds
(vl-string-subst "%%d" "d" (angtos (- pi (* 2 alpha)) 1 4)); In this Part I managed to fix
02 I made an improvement too
(setq h_t (* 0.001  (getdist (getvar "VIEWCTR") (strcat "\n ESCALE 1: "))))
03 I still have not managed to remove this command, which apparently is unnecessary and that times of error
04 I'm still trying to RE-insert this piece but the error
);end_setq
(setq att_pt 5
 t_width seg_len
);end_setq
 (setq att_pt 8
