(vl-load-com)
(DEFUN C:ALL ()
(C:LISP01)
(C:LISP02)
(C:LISP03)
(princ "\n DIGITE ALL ")
(PRINC)
(DEFUN C:LISP01 ()
(BLABLABLA)
(setq TEXTSIZE ( (getdist (strcat "\n ESCALE 1: "))))
(princ "\n SELECT OBJECT: ")
(setq XX (ssget BLABLABLA))
(Do it XX)
(PRINC)
(DEFUN C:LISP01 ()
(BLABLABLA)
(setq YY (ssget BLABLABLA))
(Do it YY)
(PRINC)
(DEFUN C:LISP01 ()
(BLABLABLA)
(setq ZZ (ssget BLABLABLA))
(Do it ZZ)
(PRINC)
(vl-load-com)
(DEFUN C:ALL ()
(C:LISP01)
(C:LISP02)
(C:LISP03)
(PRINC)
(DEFUN C:LISP01 ()
(BLABLABLA)
(Do it XX)
(PRINC)
(DEFUN C:LISP01 ()
(BLABLABLA)
(Do it YY)
(PRINC)
(DEFUN C:LISP01 ()
(BLABLABLA)
(Do it ZZ)
(PRINC)
I have a main routine c:all that calls all the others, and all will act on the same object selected, then I ask:
01-has how to make a selection for all, or ssget has limitation at this point?
02-If there is another request how do I put all this in the main programming?
Because, my vision would be something like that....
(vl-load-com)
(DEFUN C:ALL ()
(C:LISP01)
(C:LISP02)
(C:LISP03)
(vl-load-com)
(DEFUN C:ALL ()
(C:LISP01)
(C:LISP02)
(C:LISP03)
(setq TEXTSIZE1 ( (getdist (strcat "\n ESCALE 1: "))))
(setq TEXTSIZE2 ( (getdist (strcat "\n ADD TEXT "))))
(setq ALLSELECT (ssget))
(PRINC)
(DEFUN C:LISP01 ()
(BLABLABLA)
;(setq TEXTSIZE1 ( (getdist (strcat "\n ESCALE 1: "))))
;(princ "\n SELECT OBJECT: ")
(setq ALLSELECT (XX))
(ALLSELECT TEXTSIZE1)
(Do it XX)
(PRINC)
(DEFUN C:LISP01 ()
(BLABLABLA)
;(setq TEXTSIZE2 ( (getdist (strcat "\n ADD TEXT "))))
(setq ALLSELECT(YY))
(ALLSELECT TEXTSIZE2 YY)
(Do it YY)
(PRINC)
(DEFUN C:LISP01 ()
(BLABLABLA)
(setq ALLSELECT (ZZ))
(Do it ZZ)
(PRINC)
(PRINC)
(DEFUN C:LISP01 ()
(BLABLABLA)
(Do it XX)
(PRINC)
(DEFUN C:LISP01 ()
(BLABLABLA)
(Do it YY)
(PRINC)
(DEFUN C:LISP01 ()
(BLABLABLA)
(Do it ZZ)
(PRINC)
