Rc beam rebar at section lisp
abdulellah.alattab
Message 1 of 8
abdulellah.alattab
  1. Hello everyone, Kindly, can we make this program work in units of meters..
1 model space unite = 1.00 meter in my mined
Replies (7)
Message 2 of 8
Kent1Cooper
How are reinforcing-bar diameters designated in metric units?  For example, this setting:
(* (getreal "\nTop bar Size [ie. 4, 5, 6 : ] :") 0.125)
is because Imperial-units bar diameter numbers represent eighths of an inch -- a #4 bar is 4/8" [i.e. 1/2"] in diameter.  That's why it multiplies the given number by 1/8 to get an actual bar diameter to use in calculations.  You would need to use numbers appropriate to the way they are specified in metric terms [which I don't know], to get a result in meters.  Other numerical functions would also need to be adjusted similarly for metric standards -- for example, it looks like there's something in there for distance in from the concrete surface.
Kent Cooper, AIA
Message 3 of 8
smaher12
It looks like you have to multiply everything by 0.0254.
i.e.,
tb_dia (*(* (getreal "\nTop bar Size [ie. 4, 5, 6 : ] :") 0.125) 0.0254)
Message 4 of 8
Kent1Cooper
I don't think so, unless for some reason they're drawing Imperial-sized reinforcing but in Metric drawing units.  Surely metric reinforcing bars don't come in multiples-of-1/8" diameters.  Are they specified simply by diameter in millimeters, or centimeters, or maybe some kind of gauge, or shorthand numbering [like a #1 is a certain standard size, and a #2 is another, etc., but those are not dimensional numbers], or...?  What are  the standard sizes?  Etc.
Kent Cooper, AIA
Message 5 of 8
Sea-Haven
https://www.arcreo.com.au/product/deformed-reinforcing-bar download catalogue NOTE though this is for Australia.
Message 6 of 8
abdulellah.alattab
thanks autodesk " wisered
Message 7 of 8
abdulellah.alattab
thanks you are our autodesk wise man what I want is not to convert the rebar diameter in know how to convert it , what I want is to be fully by a meter unit, for example, sectoin in 300 by 600 I want to be as 0.4 units in 0.6 units in drawing
Message 8 of 8
abdulellah.alattab
scale up all lisp output drawing by 00.001
