Ranjit's code - help
F.Camargo
Advisor Advisor
Message 1 of 9
F.Camargo
Hi guys,
Based on this thread:
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/ga-lsp-is-it-possible-to-insert-tilt...
@Ranjit_Singh built that excellent code!
I'm trying to understand the code, and I need some help with this.
That code insert the text as a field and I'd like to change to text.
;;Ranjit Singh
;;8/22/17
(defun c:sf  (/ ent ang dat)
(setq o_layer (getvar 'CLAYER))
  (setq o_echo (getvar 'CMDECHO))
  (setvar 'CMDECHO 0)
  (command "_.layer" "_T" "-AREA-LOTE" "_M" "-AREA-LOTE" "c" "1" "" ""
	   "_.layer" "_T" "-AREA-LOTE" "_U" "-AREA-LOTE" "_M" "-AREA-LOTE" "c" "2" "" "")
  (setq fmt "%lu6%qf1%ps[,m²]%ds44%th46")
    ;; Text height
 (if
    (setq h (getdist (strcat "\nSpecify text height <" (rtos (getvar 'textsize)) ">: ")))
 (setvar 'textsize h)
 (setq h (getvar 'textsize))
 (mapcar '(lambda (x)
           (entmakex
            (list '(0 . "TEXT")
                  '(10 0 0 0)
                  (cons 40 h)
                  ;(cons 1
                       ;(strcat "%<\\AcObjProp Object(%<\\_ObjId "
                      ;(itoa (vla-get-objectid (vlax-ename->vla-object (setq ent x))))
                                   ;">%).Area \\f \""
		   ;fmt
		  (cons 1
              (strcat
                     (vl-string-translate "." "," (rtos (getpropertyvalue (setq ent (car (entsel "\nSeleciona Polilinha: "))) "Area") 2 2)) "m²"))
                  (cons 50
                        (+ (setq ang (progn (setq dat (cdr (reverse (vl-remove-if-not 'listp (mapcar 'cdr (entget ent))))))
                                            (apply 'angle
                                                   (cdar (vl-sort (mapcar '(lambda (x y) (cons (distance x y) (list x y))) dat (cdr dat))
        '(lambda (x y) (> (car x) (car y))))))))
                           (if (and (>= (* 1.5 pi) ang) (> ang (* 0.5 pi)))
                            pi
                            0)))
                  '(72 . 1)
                  (cons 11 (mapcar '/ (mapcar '+ (car dat) (caddr dat)) '(2 2)))
                  '(73 . 2))))
         (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "LWPOLYLINE")))))))
(setvar 'CLAYER o_layer)
(setvar 'CMDECHO o_echo)
(PRINC)
Anybody could explain to me how to do that, please?
Thank in advance
Fabricio
Replies (8)
Message 2 of 9
braudpat
Hello
Maybe you can only explode the Fields ?!
Regards, Patrice
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
Message 3 of 9
F.Camargo
@braudpat wrote:
Hello
Maye you can only explode the Fields ?!
Regards, Patrice
Thanks for replay,
But I'm studing autolisp and I'd like to know how to modify the code.
I'm trying to do that.
Fabricio
Message 4 of 9
ambrosl
What part of the code are you having difficulty understanding?
When I run the function, it creates a TEXT object with a text value and not a field.  For example, when running the function and selecting a closed polyline I got the a TEXT object with the "212,17m²" in it.
Lee Ambrosius
Senior Principal Content Experience Designer
For additional help, check out the AutoCAD Developer Documentation
Message 5 of 9
F.Camargo
I noticed the code ask me to select the polyline two times before insert the text.
That's not right!
After invoke the code, I have to select all polyline that I want to. And them put the text in all polylines.
I'd like to fix it. 🙂
Fabricio
Message 6 of 9
Ranjit_Singh
I have modified code from the original post. It should be pretty easy now to add any custom layers etc. per your above code.
;;Ranjit Singh
;;8/22/17
(defun c:somefunc  (/ ent ang dat)
           (entmakex
            (list '(0 . "TEXT")
                  '(10 0 0 0)
                  (cons 40 (getvar 'textsize))
                  (cons 1
                        (strcat "%<\\AcObjProp.16.2 Object(%<\\_ObjId "
                                ">%).Area \\f \"%lu2%pr2%ps[,m²]%ds44%th46\">%"))
                  (cons 50
                                            (apply 'angle
                            pi
                            0)))
                  '(72 . 1)
                  '(73 . 2))))
         (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "LWPOLYLINE"))))))))
Message 7 of 9
F.Camargo
Hi @Ranjit_Singh
Could you give a support in the code that I've posted?
Actually I could change the code, field text to a normal text. But isn't working properly.
After run the code I have to select the closed polylines and insert the text.
The code is ask me 2 times to select the objects, and it isn't right.
Fabricio
Message 8 of 9
Ranjit_Singh
See below changes
;;Ranjit Singh
;;8/22/17
  (setvar 'CMDECHO 0)
    ;; Text height
 (if
           (entmakex
            (list '(0 . "TEXT")
                  '(10 0 0 0)
                  (cons 40 h)
                  ;(cons 1
                                   ;">%).Area \\f \""
		   ;fmt
		  (cons 1
              (strcat
                     (vl-string-translate "." "," (rtos (getpropertyvalue x "Area") 2 2)) "m²"))
                  (cons 50
                        (+ (setq ang (progn (setq dat (cdr (reverse (vl-remove-if-not 'listp (mapcar 'cdr (entget x))))))
                                            (apply 'angle
                            pi
                            0)))
                  '(72 . 1)
                  '(73 . 2))))
(PRINC)
Message 9 of 9
F.Camargo
@Ranjit_Singh wrote:
See below changes
;;Ranjit Singh
;;8/22/17
  (setvar 'CMDECHO 0)
    ;; Text height
 (if
           (entmakex
            (list '(0 . "TEXT")
                  '(10 0 0 0)
                  (cons 40 h)
                  ;(cons 1
                                   ;">%).Area \\f \""
		   ;fmt
		  (cons 1
              (strcat
                  (cons 50
                                            (apply 'angle
                            pi
                            0)))
                  '(72 . 1)
                  '(73 . 2))))
(PRINC)
@Ranjit_Singh
Very nice!
I've wasted a couple of hours trying to understand how to do that. but no success.
Thank you very much
Fabricio
