GA.LSP - Is it possible to insert tilted text according to object rotation?
Message 1 of 14
Boa noite! Os amigos poderiam me ajudar com essa dúvida, adorei essa rotina "GA.lsp" que encontrei na publicação abaixo. O mesmo é muito útil em trabalhos topográficos! É possível que o texto seja inserido na mesma direção que o lote? Para ser inclinado de acordo com o maior comprimento do retângulo?
Como na imagem anexada à publicação! Obrigado pela ajuda de seus amigos!
Link rotina de postagem GA.LSP:   https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/area-label-lisp-routine/td-p/3347647
Download do link -  rotina GA.LSP:    https://forums.autodesk.com/autodesk/attachments/autodesk/130/302499/1/GA.lsp
Maycoln Anderson
São Paulo, Brasil
Replies (13)
Message 2 of 14
Kent1Cooper
Welcome to these Forums!
That should be achievable easily enough, if there isn't already one out there that does it that way, but questions arise:
What about non-rectangular ones?  Should the Text rotation align with the longest single edge, or the average angle between long opposite edges?
I assume there could be arc edges in some places.  What if one of the long edges is [or includes] an arc?
Also, I think it could be done much more simply.  That one HATCHes in the area temporarily, extracts the perimeter from the Hatch pattern [in a more complicated way than necessary], and constructs a Polyline boundary [and a heavy one at that!], and deletes the Hatch pattern, whereas it could just use the BOUNDARY command.
Kent Cooper, AIA
Message 3 of 14
stevor
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/length-and-width-of-rectangle-as-tex...
may have some resources, as applied to rectangles at non orthogonal orientation.
S
Message 4 of 14
Ranjit_Singh
try below for example
;: Ranjit Singh
;; 8/17/17
(defun c:somefunc  (/ ent ang dat)
 (entmakex
  (list '(0 . "TEXT")
        '(10 0 0 0)
        '(40 . 0.1)
        (cons 1
              (strcat "AREA="
                      (rtos (getpropertyvalue (setq ent (car (entsel "\nSelect rectangle: "))) "Area") 2 4)))
        (cons 50
              (+ (setq ang (progn (setq dat (cdr (reverse (vl-remove-if-not 'listp (mapcar 'cdr (entget ent))))))
                                  (apply 'angle
                                         (cdar (vl-sort (mapcar '(lambda (x y) (cons (distance x y) (list x y))) dat (cdr dat))
                                                        '(lambda (x y) (> (car x) (car y))))))))
                 (if (and (>= (* 1.5 pi) ang) (> ang (* 0.5 pi)))
                  pi
                  0)))
        '(72 . 1)
        (cons 11 (mapcar '/ (mapcar '+ (car dat) (caddr dat)) '(2 2)))
        '(73 . 2))))
Call this in your overall function with all the necessary error traps.
Message 5 of 14
F.Camargo
;: Ranjit Singh
;; 8/17/17
 (entmakex
  (list '(0 . "TEXT")
        '(10 0 0 0)
        '(40 . 0.1)
        (cons 1
              (strcat "AREA="
        (cons 50
                                  (apply 'angle
                  pi
                  0)))
        '(72 . 1)
        '(73 . 2))))
@Ranjit_Singh
Fantastic code!! Congrats!!!
It will be better if is text as a field. 🙂
Fabricio
Message 6 of 14
Ranjit_Singh
I think this will work.
;; Ranjit Singh
;; 8/17/17
 (entmakex
  (list '(0 . "TEXT")
        '(10 0 0 0)
        '(40 . 0.1)
        (cons 1
              (strcat "AREA=%<\\AcObjProp Object(%<\\_ObjId "
                      (itoa (vla-get-objectid (vlax-ename->vla-object (setq ent (car (entsel))))))
                      ">%).Area \\f \"%lu2\">%"))
        (cons 50
                                  (apply 'angle
                  pi
                  0)))
        '(72 . 1)
        '(73 . 2))))
Message 7 of 14
F.Camargo
;; Ranjit Singh
;; 8/17/17
 (entmakex
  (list '(0 . "TEXT")
        '(10 0 0 0)
        '(40 . 0.1)
        (cons 1
        (cons 50
                                  (apply 'angle
                  pi
                  0)))
        '(72 . 1)
        '(73 . 2))))
@Ranjit_Singh
Very nice code!
Thank you very much! 🙂
Regards
Fabricio
Message 8 of 14
Good afternoon! Sorry for the delay in responding! I come across this message to thank all the friends who helped, suggested ideas! Great codes, the same already meets what I need! Thank you all! God bless!
Maycoln Anderson
São Paulo, Brasil
Message 9 of 14
F.Camargo
I'm trying to modify the code to selected multiple objects.
;: Ranjit Singh
;; 8/17/17
(defun c:somefunc1  (/ ent ang dat h)
  (setq o_layer (getvar 'CLAYER))
  (setq o_echo (getvar 'CMDECHO))
  (setvar 'CMDECHO 0)
  (command "_.layer" "_T" "-AREA-LOTE" "_M" "-AREA-LOTE" "c" "1" "" ""
	   "_.layer" "_T" "-AREA-LOTE" "_U" "-AREA-LOTE" "_M" "-AREA-LOTE" "c" "2" "" "")
  ;; Text height
 (if
    (setq h (getdist (strcat "\nSpecify text height <" (rtos (getvar 'textsize)) ">: ")))
 (setvar 'textsize h)
 (setq h (getvar 'textsize))
 (entmakex
  (list '(0 . "TEXT")
        '(10 0 0 0)
        (cons 40  h);; text height
        (cons 1
              (strcat
                      (vl-string-translate "." "," (rtos (princ "\nSelect objects (polylines/circles/ellipses): ")
(getpropertyvalue (setq ent (ssget '((0 . "LWPOLYLINE,CIRCLE,ELLIPSE"))))"Area") 2 2)) "m²"))
        (cons 50
                                  (apply 'angle
                  pi
                  0)))
        '(72 . 1)
        '(73 . 2)))
(setvar 'CLAYER o_layer)
(setvar 'CMDECHO o_echo)
(PRINC)
Is it possible?
Thank in advance
Fabricio
Message 10 of 14
Good morning mate! The original code is very good, if you have the possibility to select all at once, it would be the maximum! Perfect! I'm just an autocad user, I do not understand programming! Thanks again for your work! Congratulations
Maycoln Anderson - São Paulo, Brasil
Message 11 of 14
Ranjit_Singh
Something like this to label multiple rectangles. Add error traps.
;;Ranjit Singh
;;8/22/17
 (mapcar '(lambda (x)
           (entmakex
            (list '(0 . "TEXT")
                  '(10 0 0 0)
                  '(40 . 0.1)
                  (cons 1
                                (itoa (vla-get-objectid (vlax-ename->vla-object (setq ent x))))
                  (cons 50
                                            (apply 'angle
                            pi
                            0)))
                  '(72 . 1)
                  '(73 . 2))))
         (vl-remove-if 'listp (mapcar 'cadr (ssnamex (ssget '((0 . "LWPOLYLINE"))))))))
Message 12 of 14
F.Camargo
;;Ranjit Singh
;;8/22/17
           (entmakex
            (list '(0 . "TEXT")
                  '(10 0 0 0)
                  '(40 . 0.1)
                  (cons 1
                  (cons 50
                                            (apply 'angle
                            pi
                            0)))
                  '(72 . 1)
                  '(73 . 2))))
@Ranjit_Singh
millions of kudos for you mate.
Very nice code! 🙂
I'm gonna study your code to learning good things.
Fabricio
Message 13 of 14
ArchD
I don't know if I'll ever need this, but I'm snagging a copy of it because I know if I don't get it now I'll need it in the future and won't be able to find it. Awesome.
Archie Dodge
Applications Expert - Infrastructure Solutions Division
IMAGINiT Technologies
Message 14 of 14
Congratulations! Very good! Perfect! Thanks everyone for the help!
Maycoln Anderson
São Paulo, Brasil
