Lisp to Change Color of all layers a little lighter
Mornin' all!!!
I'm looking for a lisp that will change all my layer colors by 1, basically change the shade of every layer a little lighter.
Any assistance would be grand!
Edwin.Saez
here!
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/a-lisp-to-make-all-entities-color-qu...
Edwin Saez
LinkedIn / AutoCAD Certified Professional
Si mi respuesta fue una solución para usted, por favor seleccione "Aceptar Solución", para que también sirva a otro usuarios.
this lisp changed all entities to the same color, i'm looking tfor each entity to go one shade lighter or one number lighter than the existing color ie.. 132 to 131. id like the layer to change not the entity also
Ranjit_Singh
Try below. This changes all the layers by dropping one unit from R,G and B colors.
;:Ranjit Singh
;;8/16/17
(defun c:somefunc  (/ colobj)
 (setq colobj (vla-getinterfaceobject (vlax-get-acad-object)
                                      (strcat "autocad.accmcolor." (itoa (atoi (getvar 'acadver))))))
 (vlax-for lay  (vla-get-layers (vla-get-activedocument (vlax-get-acad-object)))
  (apply 'vla-setrgb
         (cons colobj
               (mapcar '(lambda (x)
                         (if (zerop x)
                          x
                          (1- x)))
                       (mapcar '(lambda (x) (vlax-get (vla-get-truecolor lay) x)) '(red green blue)))))
  (vla-put-truecolor lay colobj)))
is here any way i can just change the ACI color up or down 1
Ranjit_Singh
Maybe like this
;;Ranjit Singh
;; 8/16/17
(defun c:somefunc  (/ latcol newind)
  (setq latcol (vla-get-truecolor lay))
  (if (= 195 (vla-get-colormethod latcol))
   (vl-catch-all-apply 'vla-put-color
                       (list lay
                             (if (zerop (setq newind (1- (vla-get-colorindex latcol))))
                              0
                              newind))))))
Thank you so much this is perfect!!!! Have a grand day!
