"Rename"/ "save as" drawing at the end of a lisp
Sandervp
Sandervp
Hello everybody,
I've got a lisp file (see clean up lisp). I want to add something at the end of this lisp that what will save this drawing as "XREF - drawing name".
Drawing 1 becomes xref-drawing 1, drawing 2 becomes xref-drawing 2, etc.
Is this possible?
hmsilva
Try
(defun xfile (/ file)
    (setq file (strcat (getvar 'dwgprefix) "XREF-" (getvar 'dwgname)))
    (if (findfile file)
        (command "_.-wblock" file "Y" "*")
        (command "_.-wblock" file "*")
and add a call to the 'xfile' function at the end of your clean up lisp... (xfile)
Hope this helps,
Henrique
Sandervp
Thanks again Henrique!
The text "xref-" becomes a part of the filename now. If I want to change this (in the future) into "example-xref.dwg" instead of "xref-example.dwg", the only thing I have to change in the code is:
   (setq file (strcat (getvar 'dwgprefix) (getvar 'dwgname) "-XREF" ))
instead of:
hmsilva
instead of:
You're welcome, Sandervp!
No,
(getvar 'dwgname) will return "xxx.dwg", we have to remove the file extension from the file name, one way
(setq file (strcat (getvar 'dwgprefix) (vl-filename-base (getvar 'dwgname)) "-XREF" ))
Hope this helps,
Henrique
