"Find and replace" range of numbers
cherrygate
Message 1 of 12
cherrygate
I have this script I am currently using to remove crap data
(defun c:Fix_Labels
  (/ tss)(vl-load-com)
  (setq findText '("01." "02." "03." "04." "05." "06." "07." "08." "09." "10." "11." "12." "1900" "1901" "1902" "1903" "1904" "1905" "1906" "1907" "1908" "1909" "1910" "1911" "1912" "1913" "1914" "1915" "1916" "1917" "1918" "1919" "1920" "1921" "1922" "1923" "1924" "1925" "1926" "1927" "1928" "1929" "1930" "1931" "1932" "1933" "1934" "1935" "1936" "1937" "1938" "1939" "1940" "1941" "1942" "1943" "1944" "1945" "1946" "1947" "1948" "1949" "1950" "1951" "1952" "1953" "1954" "1955" "1956" "1957" "1958" "1959" "1960" "1961" "1962" "1963" "1964" "1965" "1966" "1967" "1968" "1969" "1970" "1971" "1972" "1973" "1974" "1975" "1976" "1977" "1978" "1979" "1980" "1981" "1982" "1983" "1984" "1985" "1986" "1987" "1988" "1989" "1990" "1991" "1992" "1993" "1994" "1995" "1996" "1997" "1998" "1999" "2000" "2001" "2002" "2003" "2004" "2005" "2006" "2007" "2008" "2009" "2010" "2011" "2012" "2013" "2014" "2015" "2016" "2017" "2018" "2019" "2020" "2021"))
  (setq replaceText "")
  (foreach item findText
    (if (setq ss (ssget "X" (list '(0 . "*TEXT") (cons 1 (strcat "*" item "*")))))
      (repeat (setq i (sslength ss))
        (setq ed (entget (ssname ss (setq i (1- i)))))
        (setq tx (cdr (assoc 1 ed)))
        (setq tx (vl-string-subst replaceText item tx))
        (entmod (subst (cons 1 tx) (assoc 1 ed) ed)))))
  (setq findText '("0000" "000"))
  (setq replaceText "P.")
It needs to do it in the same order of find + replace that I have it doing now, but also there are two conditions it doesn't handle that I would like to:
1. "00" replace with P. - but ONLY after the script has evaluated the rest of my list, AND ONLY if it is at the beginning of a number (For example: 001234 would be P.1234 BUT 123400 would NOT be changed to be 1234P.)
2. After all of that is evaluated, I have a very large number range of numbers I want to be removed (3100000-3200000)
Any help to tweak this script, or create a whole new one would be highly appreciated. Thank you!
Replies (11)
Message 2 of 12
pbejse
Please show some more example of the target and result.
"WHAT IT IS NOW" --> WHAT NOW"
Message 3 of 12
marko_ribar
Maybe this could be useful :
http://www.theswamp.org/index.php?topic=4591.msg605179#msg605179
Marko Ribar, d.i.a. (graduated engineer of architecture)
Message 4 of 12
ronjonp
This should do that:
(if (setq s (ssget "_x" '((0 . "TEXT") (1 . "00*"))))
  (foreach e (mapcar 'cadr (ssnamex s))
    (entmod (append (entget e) (list (cons 1 (strcat "P." (substr (cdr (assoc 1 (entget e))) 3))))))
Message 5 of 12
cherrygate
 There is so much crap data, it's hard to give a good example of that, unfortunately.
But those generic "rules" I said should handle most scenarios and the ones it doesn't probably have to be manually trimmed anyway.
Message 6 of 12
john.uhden
Seems to me you're gonna hafta use wcmatch to test if a string matches your intentions.
John F. Uhden
Message 7 of 12
pbejse
On your post you are targetting 3 to four zeros ,
does that now include two zeros as well?
   (if	(setq ss (ssget "_x" '((0 . "TEXT") (1 . "* 000*,000*")))
	(setq crap (vl-some '(lambda (z)
		    (if (vl-string-search z tx) z))
			  '("0000" "000")))
	(setq tx (vl-string-subst replaceText crap tx))
HTH
Message 8 of 12
Sea-Haven
Like pbe a loop that looks at each character is it  "0" so you could have as many as you like "0000013"  then use substr to remake the value with a P.13 So my $0.05 Note the test values 0000 etc.
(setq findText '("00001." "002." "03." "000004." "0005." "006." "07." "08." "09." "10." "11." "12." "1900" "1901" "1902" "1903" "1904" "1905" "1906" "1907" "1908" "1909" "1910" "1911" "1912" "1913" "1914" "1915" "1916" "1917" "1918" "1919" "1920" "1921" "1922" "1923" "1924" "1925" "1926" "1927" "1928" "1929" "1930" "1931" "1932" "1933" "1934" "1935" "1936" "1937" "1938" "1939" "1940" "1941" "1942" "1943" "1944" "1945" "1946" "1947" "1948" "1949" "1950" "1951" "1952" "1953" "1954" "1955" "1956" "1957" "1958" "1959" "1960" "1961" "1962" "1963" "1964" "1965" "1966" "1967" "1968" "1969" "1970" "1971" "1972" "1973" "1974" "1975" "1976" "1977" "1978" "1979" "1980" "1981" "1982" "1983" "1984" "1985" "1986" "1987" "1988" "1989" "1990" "1991" "1992" "1993" "1994" "1995" "1996" "1997" "1998" "1999" "2000" "2001" "2002" "2003" "2004" "2005" "2006" "2007" "2008" "2009" "2010" "2011" "2012" "2013" "2014" "2015" "2016" "2017" "2018" "2019" "2020" "2021"))
(defun c:test ( / x y str f )
(repeat (setq y (length findtext))
	(setq str (nth (setq y (- y 1)) findtext))
	(if (= (substr str 1 1 ) "0")
	(progn
		(setq f "No" x 2)
		(while (= f "No")
		(setq ans (substr str x 1 ))
		(if (= ans "0")
			(setq x (+ x 1))
			(setq f "yes")
		(princ (strcat "\n" (rtos y 2 0)))
		(setq findtext (subst (strcat "P" (substr str x (- (strlen str) (- x 1)))) str findtext))
(princ)
(c:test)
Message 9 of 12
ronjonp
@Sea-Haven
This is how I'd remove leading zeroes.
(defun c:foo (/ s)
  (if (setq s (ssget "_x" '((0 . "TEXT") (1 . "0*"))))
      (entmod
	(append	(entget e)
		(list (cons 1 (strcat "P." (vl-string-left-trim "0" (cdr (assoc 1 (entget e)))))))
  (princ)
Message 10 of 12
stevor
And for #2, (3100000-3200000), try:
 (ssget "_x" '((0 . "TEXT") (1 . "31#####")))
 (ssget "_x" '((0 . "TEXT") (1 . "3200000")))
S
Message 11 of 12
ronjonp
Those could be combined like so 🙂
(ssget "_X" '((0 . "TEXT") (1 . "31#####,3200000")))
Message 12 of 12
pbejse
@stevor wrote:
And for #2, (3100000-3200000)try:
I take it the items on the list are month < "05." > and year < "1984" >
I still dont get what the OP meant by that range really, thats why i'm asking for more sample string.
If its just that range then its too easy to replace.
