"Export text to CSV" LISP gives error in 2023 but not in 2019
EBDBC3D
Message 1 of 8
EBDBC3D
This lisp routine technically works but gives an error message of "too many arguments" in Civil 3D 2023. It doesn't in 2019. Any obvious reason why?  Also, it makes the .csv read-only until I close the drawing. Thanks!
(defun c:EXP2CSV ()
(setq file (getfiled "Save CSV file" "" "csv" 1))
(if file
(progn
(setq seltext (ssget))
(if seltext
(progn
(setq f (open file "W"))
(setq numtexts (sslength seltext))
(if (> numtexts 0)
(progn
(repeat numtexts
(setq ent (ssname seltext (setq numtexts (1- numtexts))))
(setq text (cdr (assoc 1 (entget ent))))
(write-line (strcat "\"" (text-to-csv-string text) "\"") f)
(close f)
(princ "\nText exported to CSV successfully!")
(princ "\nNo text entities found.")
(princ "\nNo valid selection.")
(princ "\nInvalid file selection.")
(princ)
(defun text-to-csv-string (val)
(if (or (wcmatch (strcat val "") "*e*") (wcmatch (strcat val "") "*E*"))
(strcat "\"" (strcat val "\""))
(strcat val)
Replies (7)
Message 2 of 8
paullimapa
not sure if this is the issue since I don't have Civil 3D, but your selection doesn't filter out just TEXTS so it would crash if you selected other non Text objects:
(ssget)
vs
(ssget '((0 . "TEXT")))
Paul Li
IT Specialist
@The Office
Message 3 of 8
Sea-Haven
What looks like text maybe CIV3D labels, gogo pts etc use Paullimapa suggestion 1st. (text-to-csv-string text)  needs *Text objects, can get the label details but in different way.
Message 4 of 8
hosneyalaa
@EBDBC3D
Hi
Please attached drawing example
Message 5 of 8
EBDBC3D
Thanks, I added that. Still get the error message though. I'm just using it for plain AutoCAD text, no Civil 3D entities. It works with no error message in 2019 for some reason.
Message 6 of 8
paullimapa
I don't see a lot of places in the code that would actually call for another function with arguments that may be missing.
Perhaps try doing the following trouble shooting on your own in 2023:
At AutoCAD command line type:
See if you get a window for file selection and then see if the csv file selected is returned.
I also changed your code in the following sections...
to:
(setq f (open file "w"))
(strcat val)
to:
;  (if (or (wcmatch (strcat val "") "*e*") (wcmatch (strcat val "") "*E*"))
  (if (wcmatch (strcase val) "*E*")
(strcat val)
and I moved it to the beginning of the code
I also localized all the functions and variables so this code is using it's own not any others
See if this makes a difference
Paul Li
IT Specialist
@The Office
Message 7 of 8
EBDBC3D
Thanks, I'll use that version. 2023 still gives the error message, but it still seems to work. We've had lots of minor glitches like that with the switch to 2023.
Message 8 of 8
paullimapa
hopefully autodesk will issue updates to C3D 2023 to correct this issue. you may want to contact them directly to see if they'll respond.
Contact Customer Support | Autodesk Support
Paul Li
IT Specialist
@The Office
