Hello, lisp , I want to get the path without the last folder
eng_minamaged
Message 1 of 24
eng_minamaged
Hello, lisp , I want to get the path without the last folder  (setq my-path "C:\\Users\\Username\\Documents\\Folder1\\Folder2\\")
Replies (23)
Message 2 of 24
paullimapa
here's one way by splitting the path into separate elements and then combine all back dropping the last element in the list:
; function to drop last folder in given path
; Argument:
; tst = folder path as a string
; Example:
; (droplastdir "C:\\Autodesk\\Test")
; Returns:
; "C:\\Autodesk"
(defun droplastdir (tst / aec_str2lst dir i new)
(vl-load-com)
;;;--- aec_str2lst function
; splits given string with separator
; returns list with each item
; https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/how-do-i-split-a-file-path-into-bits-based-on-back-slash/td-p/2396237
; Usage:
; (aec_str2lst (findfile "acad.exe") "\\")
; Returns:
; ("C:" "Program Files" "Autodesk" "AutoCAD 2020" "acad.exe")
; Usage:
; (aec_str2lst "0 1 2 3" " ")
; Returns:
; ("0" "1" "2" "3")
(defun aec_str2lst (str sep / pos)
  (if (setq pos (vl-string-search sep str))
   (cons (substr str 1 pos)
    (aec_str2lst (substr str (+ (strlen sep) pos 1)) sep)
   (if(not(zerop(strlen str)))(list str))
) ; defun
(if (equal (setq dir (aec_str2lst tst "\\")) (list tst)) ; if no change
 (setq new tst) ; no change
 (progn
  (setq new "" i 0)
  (repeat (1- (length dir))
   (setq new (strcat new "\\" (nth i dir)))(setq i(1+ i))
  (if (= "" (setq new (substr new 2 (1- (strlen new)))))(setq new (car dir)))  ; if empty string
 ) ; progn
) ; if
new
) ; defun
Paul Li
IT Specialist
@The Office
Message 3 of 24
komondormrex
hi,
check this
(if (= "\\" (substr my-path (strlen my-path) 1))
	(setq before-last-my-path (strcat (vl-filename-directory (vl-filename-directory my-path)) "\\"))
       	(setq before-last-my-path (strcat (vl-filename-directory my-path) "\\"))
Message 4 of 24
Kent1Cooper
then
(substr my-path 1 (1+ (vl-string-position 92 (substr my-path 1 (1- (strlen my-path))) 1 T)))
returns
"C:\\Users\\Username\\Documents\\Folder1\\"
Kent Cooper, AIA
Message 5 of 24
eng_minamaged
I am sure this is true code but I can't test it because I don't have the ability to understand lisp code
Message 6 of 24
paullimapa
Actually very straightforward to test
just save the attached droplastdir.lsp file to a folder in your c: drive and then drag&drop it into your AutoCAD graphics window
Then at the command prompt enter the following:
(droplastdir my-path)
AutoCAD should return:
"C:\\Users\\Username\\Documents\\Folder1"
Paul Li
IT Specialist
@The Office
Message 7 of 24
eng_minamaged
I appreciate your help... If I want the save current drawing to the new path
Message 8 of 24
paullimapa
Try
(setq dwgname (strcat (droplastdir my-path) "\\" (vl-filename-base (getvar"dwgname")))) (vla-saveas (vla-get-ActiveDocument (vlax-get-Acad-Object)) dwgname)
Paul Li
IT Specialist
@The Office
Message 9 of 24
eng_minamaged
Ok I am sorry but it give me error if i want to  create new folder beside last folder in path
Not in last folder but beside it
"new drawings" and then save as in it
(setq result (substr result 1 (1+ (vl-string-position 92 (substr result 1 (1- (strlen result))) 1 T))))
(setq result (vl-string-left-trim "\\" result)) ; Remove leading backslashes
(setq result (vl-string-right-trim "\\" result)) ; Remove trailing backslashes
(vl-mkdir strcat result "/new  Drawings/")
(if (< (getvar "expert") 2) ; add to chk setting
(command "_.SAVEAS" "" (strcat result "/new  Drawings" "\\" (nth n Files_Folder)) "_Yes")
Message 10 of 24
paullimapa
no worries:
(setq newdir "new drawings")
(setq newprefix (strcat (droplastdir (getvar"dwgprefix")) "\\" newdir))
(setq dwgname (vl-filename-base (getvar"dwgname")))
(vl-mkdir newprefix)
(vla-saveas (vla-get-ActiveDocument (vlax-get-Acad-Object)) (strcat newprefix "\\" dwgname))
Paul Li
IT Specialist
@The Office
Message 11 of 24
eng_minamaged
@paullimapa could you tell me what is the error in my code?
Message 12 of 24
paullimapa
what error is it showing?
Paul Li
IT Specialist
@The Office
Message 13 of 24
eng_minamaged
I use lisp to run code on folder of dwgs and I want to save as it in new folder beside the last folder but it can't save as I think there as error in line of save as in path
Message 14 of 24
paullimapa
perhaps you meant for @Kent1Cooper to look at this because it's not the same code I provided you to run.
Paul Li
IT Specialist
@The Office
Message 15 of 24
eng_minamaged
If any advice I will be gratfull
Message 16 of 24
paullimapa
I'm just a bit confused by what you're attempting to do with these particular way of composing the code.
Like what is this attempting to do?
What does the original result stand for?
My assumption would be:
(setq result (getvar"dwgprefix"))
This would then be the current drawing's path which would be similar to your original line of code in your OP:
And drop the last folder returning this as result:
Then why would you need this line of code immediately afterwards:
Do you expect to have "\\" in front of C:\\ which you do not have?
Next, why do you need this line of code?
You'll now get this as result after running the above line:
Then you decide to add the slash back but as a forward slash to create the new folder after result:
but this line of code fails because you're missing parenthesis and you don't need an additional slash at the end so it should look like this instead:
(vl-mkdir (strcat result "/new  Drawings"))
Lastly, with this line of code, what is Files_Folder set equal to which is not anywhere in the previous lines of code?
Paul Li
IT Specialist
@The Office
Message 17 of 24
komondormrex
if files_folder is a list of filenames you want to save in newly created "New Drawings" adjacent folder to "folder2", check the code below
	  new_folder "New Drawings"
	(setq adjacent_folder (strcat (vl-filename-directory (vl-filename-directory my-path)) "\\" new_folder))
    (setq adjacent_folder (strcat (vl-filename-directory my-path) "\\" new_folder))
(if (vl-mkdir adjacent_folder)
	(foreach file Files_Folder
		(command "_.SAVEAS" "" (strcat adjacent_folder "\\" file) "_Yes")
Message 18 of 24
eng_minamaged
@komondormrex it is like magic . Thank you very much for your help and for your time Thank @komondormrex @paullimapa @Kent1Cooper . And @paullimapa  I am very sorry for you. I am really afraid of the big codes, but of course, you are making a great effort because you have helped many people, and of course I am one of them.
Message 19 of 24
eng_minamaged
If the folder "New Drawings" exists it won't save the drawings in it.. I want to create it if not exist if not...... save the drawings in it
Message 20 of 24
paullimapa
(if(not(vl-directory-p (strcat result "/new  Drawings")))(vl-mkdir (strcat result "/new  Drawings")))
Paul Li
IT Specialist
@The Office
