"Copy" Lisp
"Copy" Lisp
sambaldan
"Copy" Lisp
sambaldan
I'm currently using variations of
(defun c:CY (/ ss bp)
(if (and (setq ss (ssget "_:L"))
(setq bp (getpoint "\nSpecify base point: "))
(command "_.copy" ss "" "_non" bp ".XZ" "_non" bp)
(princ)
for copying in .XZ, .YZ and .Z Axis only without having to type the whole ".XY" etc. and it works great. However, after one copy it finishes the command. I was wondering if there was a way to keep it copying a single item, in the same axis from the same base point continuously until cancelled - as the normal 'copy' command does.
Any help would be really appreciated.
SB
ВeekeeCZ
Try this...
    (progn
      (command "_.copy" ss "" "_m" "_non" bp)
      (while (< 0 (getvar 'CMDACTIVE))
        (command ".XZ" "_non" bp PAUSE))))
  (princ)
sambaldan
Works perfectly.
Thank you!
