Add color to Layer
Add color to Layer
C.Utzinger
Message 1 of 21
Add color to Layer
C.Utzinger
Hi
It's a simple thing. I just want to add a color to the Layer... How????
(defun c:<Test3 ()
  (tolayer (ssget "_:L") "-I-Ansicht")
  (princ)
) ;_ end of defun
(defun tolayer ( ss lay / i e )
  (repeat (setq i (sslength ss))
    (entmod
      (subst
	(cons 8 lay)
        (assoc 8 (entget (setq e (ssname ss (setq i (1- i))))))
        (entget e)
Thank you in advance...
Accepted solutions (3)
Replies (20)
Message 2 of 21
ВeekeeCZ
Like this maybe?
(defun c:<Test3 ()
  (tolayer (ssget "_:L") "-I-Ansicht" "2")
  (princ)
  ) ;_ end of defun
(defun tolayer ( ss lay col / i e )
  (if (tblsearch "LAYER" lay)
    (command "_.-LAYER" "_C" col lay "")
    (command "_.-LAYER" "_N" lay "_C" col lay ""))
    (entmod
      (subst
        (cons 8 lay)
        (entget e)
Message 3 of 21
C.Utzinger
Hi
I thought it is better without using command...?
Message 4 of 21
C.Utzinger
I'm just trying another Thing, but with no idea how to do it...
I want to have both Option, or change a previous selected object, or draw a poliline...
Is that possible???
(defun c:<Test3 ()
(if (ssget "_:L")(progn
  		 (tolayer (ssget "_:L") "-I-Ansicht" "6")
  		 (princ))
		 (progn
  		 (command "_.-LAYER" "_m" "-I-Ansicht" "_co" "6" "-I-Ansicht" "")
		 (command "_pline" (while (> (getvar "cmdactive") 0) (command pause)))
		 (prin1))
) ;_ end of defun
    (entmod
      (subst
        (cons 8 lay)
        (entget e)
Message 5 of 21
ВeekeeCZ
Don't think so.
(defun c:<Test3 ()
  (tolayerwithcolor (ssget "_:L") "-I-Ansicht" 2)
  (princ)
(defun tolayerwithcolor ( ss lay col / i e d)
  (if (and (tblsearch "LAYER" lay)
           (setq d (entget (tblobjname "LAYER" lay))))
    (entmod (subst (cons 62 col)
                   (assoc 62 d)
                   d))
    (entmake (list (cons 0 "LAYER")
                   (cons 100 "AcDbSymbolTableRecord")
                   (cons 100 "AcDbLayerTableRecord")
                   (cons 2 lay)
                   (cons 62 col)
                   (cons 70 0))))
    (entmod
      (subst
        (cons 8 lay)
        (entget e)))))
Message 6 of 21
ВeekeeCZ
Is that possible???
Don't have time to make it nicer, so just simple if conditions...
(setq ss (ssget "I"))			; pre-selection
(if (not ss)
  (setq pt (getpoint "\nDraw a polyline or <select objects to layer change>: ")))
(if (not pt)
  (setq ss (ssget)))
(layerset) 				; check layer existence, set color
(if pt
  (draw-polyline))                     ; set current lay, use pt as the first point of polyline
(if ss
  (tolayer))
BTW What is do a lot for myself is that if I have something pre-selected, then it does one thing, if don't then the other. This task might fit for this.
Message 7 of 21
C.Utzinger
I'm so stupid
It was just like this:
(defun c:<Test3 ()
(if (ssget "I")(progn
  		 (tolayer (ssget "I") "-I-Ansicht" "6")
  		 (princ))
		 (progn
		 (prin1))
) ;_ end of defun
    (entmod
      (subst
        (cons 8 lay)
        (entget e)
Sorry... Thank you
Message 8 of 21
ВeekeeCZ
Almost.
- wrong parenthesis around PLINE part
- a routine should never change any SYSVAR without setting it BACK!!!
(defun c:<Test3 ( / *error* olay :tolayer)
  (defun *error* (errmsg)
    (if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
      (princ (strcat "\nError: " errmsg)))
    (setvar 'CLAYER olay)
    (princ))
  (defun :tolayer ( ss lay col / i e )
      (entmod (subst (cons 8 lay)
                     (entget e)))))
  (setq olay (getvar 'CLAYER))
  (if (ssget "_I")
    (:tolayer (ssget "_I") "-I-Ansicht" "6")
    (progn
      (command "_.PLINE")
      (while (> (getvar 'CMDACTIVE) 0) (command PAUSE))))
  (princ)
Message 9 of 21
C.Utzinger
HI
Thank you about the wrong parenthesis around PLINE part...
Just in this case I want to change the layer to -I-Ansicht.
This is my finished version...
Tell me please if something is wrong...
Kind regards.
(defun c:<Test3 ( / *error* cmd)
    (setvar 'CMDECHO cmd)
    (command-s "_.undo" "_end")
    (princ))
      (entmod
        (subst
          (cons 8 lay)
          (entget e)))))
(setq cmd (getvar 'CMDECHO))
		 (prompt "\nObjekt/e auf Layer -I-Ansicht gewechselt!")
  		 (princ))
		 (progn
		 (command "_.undo" "_begin")
		 (setvar 'CMDECHO 1)
		 (command "_.pline")
		 (command "_.undo" "_end")
		 (prin1))
) ;_ end of defun
Message 10 of 21
ВeekeeCZ
We usually use the CMDECHO in the other way around. We presume that the most people have it ON and we turn it off if we need it.
But I thing it's good to go... Cheers!
Message 11 of 21
C.Utzinger
Yeah!
The Problem is when CMDECHO is off, then PLINE dos not show the options in the command line (pick first Point, pick next point, etc.)
Or is there another way to show these Options?
Thank you again...Smiley Happy
Kind regards.
Message 12 of 21
ВeekeeCZ
The question is why it is OFF? It should be ON by default.
I presume that the answer is because of some other routine which was not finished (and written) correctly, so it left CMDECHO off. You should fix the other routines...
No better way - just make sure that your have it in *error* function.
Message 13 of 21
Kent1Cooper
@c.utzinger wrote:
This is my finished version...  Tell me please if something is wrong...
I would suggest you add tolayer to the localized variables list.
Also, consider adding a saving of the current Layer at the beginning, and resetting of it at the end and in the *error* handler.
In case you care, that entire (repeat) function that makes up the bulk of the (tolayer) function could be replaced by this, eliminating the need to step through the selection and change each object's layer separately:
(command "_.chprop" ss "" "_layer" lay "")
Kent Cooper, AIA
Message 14 of 21
C.Utzinger
Hi
I have a Little fight with AutoCAD. The CMDECHO is always off, i can Close it with "1" and when i open a empty drawing it is "0" again.
What can i do...?
Message 15 of 21
ВeekeeCZ
Use acaddoc.lsp, see HERE, find it using (file "acaddoc.lsp") or create one, save it on search path...
At the end of it add the line...
(setvar 'CMDECHO 1)
You can use SYSVARMONITOR to help you with finding which routine changes that setting.
Message 16 of 21
C.Utzinger
Do you remember the stupid program? This Change it to "0"!!!!!!!!
I'm so f.....g angry!!!!!!!!!!!!
I will write them again!
Thank you for your help...
Message 17 of 21
C.Utzinger
I just found a Problem with the Routine.
When someone has turned of PICKFIRST, then it doesn't work.
I can not (or don't know how) put (setvar 'PICKFIRST 1) before the Routine starts, it don´t work... The selection gets away I think.
What can I do?
Message 18 of 21
ВeekeeCZ
Nothing you can do about it. Go back to my post #6 and allow <select object to layer change>
Message 19 of 21
C.Utzinger
Hi
One more question.
If the layer exists and it is off, then I don't want it on, it should just stay off.
Can you help me with that?
I tried something with this, but got nothing:
(<(cdr (assoc 62 (entget (tblobjname "layer" "LayerNameHere"))))0)
Message 20 of 21
Kent1Cooper
If I'm looking at the right code, it looks to me as though the only thing that would turn on a Layer that's off is the Layer command with the Make option in it [anything that sets a Layer current in a Layer command -- Set or Make options -- turns it on if it's off].  Just after that you draw a Polyline, which it is possible to do on a Layer that's off, but that makes no sense to me.  So if the Layer exists and is off, should the routine not only leave it off but also not go into the Pline command?  Or am I misunderstanding something?
Kent Cooper, AIA
