"Command: ; error: extra right paren on input"
pesctx
pesctx
I'm trying to load this lisp file and I receive "Command: ; error: extra right paren on input".
I put one or 2 parenthesis at the finish of the file, but I receive the same error.
Any help please.
;Show flow direction
;Stefan M. - 26.07.2015
(defun c:flow ( / *error* ms ss e l key d n c y p f a p1 p2 p3 ar)
 (or acDoc (setq acDoc (vla-get-activedocument (vlax-get-acad-object))))
 (setq ms (vlax-get acDoc (if (= 1 (getvar 'cvport)) 'paperspace 'modelspace)))
 (vla-startundomark acDoc)
 (defun *error* (msg)
   (and
     msg
     (not (wcmatch (strcase msg) "*CANCEL*,*QUIT*,*EXIT*"))
     (princ (strcat "\nError: " msg))
   (vla-endundomark acDoc)
   (princ)
 (if
   (eq (vla-get-lock (vla-get-activelayer acdoc)) :vlax-true)
   (progn
     (princ "\nCurrent Layer is locked.")
     (exit)
 (if
   (setq ss (ssget ":E:S" '((0 . "POLYLINE") (-4 . "&=") (70 . )))
   (progn
     (or (tblsearch "layer" "arrow") (vla-add (vla-get-layers acDoc) "arrow"))
     (setq e (ssname ss 0)
           l (vlax-curve-getdistatpoint e (vlax-curve-getendpoint e))
     (initget "Distance Items" 1)
     (setq key (getkword (strcat "\nPolyline length = " (rtos l) "\nChoose a method [Distance/Items]: ")))
     (if
       (eq key "Distance")
       (setq d (getdist "\nDistance between arrows: "))
       (setq n (getint  "\nNumber of arrows: "))
     (if n (setq d (/ l n)))
     (if d
       (progn
         (setq c 0.0 y (/ d 5.0))
         (while (< (setq c (+ c d)) l)
           (setq p (vlax-curve-getpointatdist e c)
                 f (vlax-curve-getfirstderiv e (vlax-curve-getparamatpoint e p))
                 a (angle '(0.0 0.0) f)
                 p1 (polar p a (if (minusp (caddr f)) (- y) y))
                 p2 (polar p1 (+ a (* pi 0.5)) (* 0.4 y))
                 p3 (polar p1 (- a (* pi 0.5)) (* 0.4 y))
                 ar (vla-Add3DPoly ms
                      (vlax-safearray-fill
                        (vlax-make-safearray vlax-vbDouble '(0 . )
                        (append p2 p p3)
           (vla-put-closed ar :vlax-true)
;;;            (vla-put-color ar (if (minusp (caddr f)) acred acyellow))
           (vla-put-layer ar "arrow")
 (*error* nil)
 (princ)
The code is from here:  https://www.cadtutor.net/forum/topic/57478-arrow-on-3d-polyline-to-show-water-flow-direction/
Sea-Haven
Ok 1st thing download Notepad++ it has in built lisp checking, or use VLIDE.
Not saying this is correct but seems right
   (and
     msg
   (princ)
 (if
   (progn
     (exit)
 (if
   (progn
     (if
       (eq key "Distance")
     (if d
       (progn
                        (append p2 p p3)
 (*error* nil)
 (princ)
pesctx
I tried to load it on Autocad 2015 and 2018 using the command appload.
I receive the same error: "Command: ; error: extra right paren on input"
Vlide tells it's ok.
ВeekeeCZ
There are some pieces in the code left unfinished.
  (or acDoc
    (and msg
    (princ)
  (if (eq (vla-get-lock (vla-get-activelayer acdoc)) :vlax-true)
    (progn
      (exit)
  (if (setq ss (ssget ":E:S" '((0 . "POLYLINE"))))
    (progn
	    l (vlax-curve-getdistatpoint e (vlax-curve-getendpoint e)))
      (if (eq key "Distance")
      (if n
	(setq d (/ l n)))
      (if d
	(progn
	  (setq c 0.0
		y (/ d 5.0))
			 (vlax-make-safearray vlax-vbDouble (cons 0 (1- (length (append p2 p p3)))))
			   (append p2 p p3))))
	    (vla-put-layer ar "arrow"))))))
  (*error* nil)
  (princ)
pesctx
It's working. Thank you very much.
Sea-Haven
Nice one BeekeeCZ, using Notepad ++ makes checking easy as you create looking for these problems.
Here is an old one written like 30  years ago gives an idea of where mismatched.
