If I understood your need the code should only work with MultiLineText and MultiLineAttributes, am I right?
I hope it helps.
Best regards, Luís Augusto
;; Quick Field Program - Lee Mac ;;
;; Program Description ;;
;; This function is designed to enable the user to quickly create ;;
;; custom programs for inserting multiple fields into a drawing. ;;
;; This could be for use in situations in which the user is required ;;
;; to create many fields in a drawing, with each field referencing ;;
;; the same object property, and continued use of the Field Command ;;
;; Dialog can become tedious. ;;
;; Custom programs can be created by calling the 'LM:quickfield' ;;
;; function with a string describing the object property to be ;;
;; referenced by the field; a string describing the field formatting; ;;
;; and an integer to determine how the field will be created. ;;
;; When creating the custom field programs, the user is advised to ;;
;; first use the Field Command dialog with all settings set to create ;;
;; the desired field, then make note of the Field Expression ;;
;; displayed at the bottom of the dialog. The required QuickField ;;
;; parameters may then be read directly from this Field Expression. ;;
;; Each parameter is described in more detail below. ;;
;; Notes on QuickField Parameters ;;
;; 'prop' [STR] ;;
;; This parameter is a string describing the object property to be ;;
;; referenced by the field. ;;
;; Example: ;;
;; Field Expression displayed in Field Command Dialog: ;;
;; %<\AcObjProp Object(%<\_ObjId 2129673136>%).Area \f "%lu6%qf1">% ;;
;; For the above expression, the object property is "Area" ;;
;; 'format' [STR] ;;
;; This parameter is a string describing the field formatting for the ;;
;; object property that is to be displayed. ;;
;; If no formatting is to be used, 'format' should be an empty ;;
;; string (""). ;;
;; Example: ;;
;; For the above expression, the field formatting is "%lu6%qf1" ;;
;; This formatting string indicates that the Area property of the ;;
;; object will be displayed using the current units and precision in ;;
;; the drawing. ;;
;; 'mode' [INT] ;;
;; This integer parameter determines how the field should be created ;;
;; in the drawing. ;;
;; mode = 1 : Replace Existing Text / MText / Attribute string. ;;
;; This mode will prompt the user to select an existing ;;
;; object to contain the field. ;;
;; mode = 2 : Create Text Object ;;
;; The user will be prompted to pick a point at which a ;;
;; Text Object containing the field will be created. ;;
;; mode = 3 : Create MText Object ;;
;; This user will be prompted to pick a point at which ;;
;; an MText Object containing the field will be created. ;;
;; Example Custom Field Programs ;;
;; Example Program #1: ;;
(defun c:test1 ( ) (LM:QuickField "Area" "%lu6%qf1" 2))
;; Here, ;;
;; prop = "Area" ;;
;; format = "%lu6%qf1" ;;
;; mode = 2 ;;
;; This program will hence prompt the user to select an object with ;;
;; the "Area" property, then prompt for a point at which to create a ;;
;; Text Object (mode=2) containing the field. ;;
;; The displayed Area will be formatted using the current settings ;;
;; for Units and Precision. ;;
;; Example Program #2: ;;
(defun c:test2 ( ) (LM:QuickField "Length" "%lu2%pr3%ps[Length:,]%ct8[0.1]" 3))
;; Here, ;;
;; prop = "Length" ;;
;; format = "%lu2%pr3%ps[Length:,]%ct8[0.1]" ;;
;; mode = 3 ;;
;; This program will prompt the user to select an object with the ;;
;; "Length" property (Lines / LWPolylines / Polylines), then prompt ;;
;; for a point at which to create an MText Object (mode=3) containing ;;
;; the field. ;;
;; The Length value will be formatted... ;;
;; - in Decimal Units (%lu2) ;;
;; - to a Precision of 3 d.p. (%pr3) ;;
;; - with a Prefix of "Length:" (%ps[Length:,]) ;;
;; - with a Conversion Factor of 0.1 (%ct8[0.1]) ;;
;; Example Program #3: ;;
(defun c:test3 ( ) (LM:QuickField "StyleName" "%tc1" 1))
;; Here, ;;
;; prop = "StyleName" ;;
;; format = "%tc1" ;;
;; mode = 1 ;;
;; "StyleName" property (Text / MText / ...anything with a Style), ;;
;; then prompt for an existing object (mode=1) to house the field. ;;
;; The referenced StyleName property will be displayed as ;;
;; uppercase (%tc1). ;;
(defun c:AddArea ( ) (LM:QuickField "Area" "%lu2%pr0%ps[,m²]%ct8[0.000001]%th44" 1))
;; Here, ;;
;; mode = 3 ;;
;; the field. ;;
;;--------------------------=={ Quick Field }==-------------------------;;
;; Creates a field using the method encoded by the 'mode' argument, ;;
;; using the supplied field property and format strings. ;;
;; Author: Lee Mac, Copyright © 2011 - www.lee-mac.com ;;
;; Arguments: ;;
;; prop - Object Property to link to field (e.g. "Area") ;;
;; format - Field formatting string (use "" for none) ;;
;; mode - Integer to determine how the field is created ;;
;; mode=1 : Replace Existing Text, MText, Attribute ;;
;; mode=2 : Create Text Object ;;
;; mode=3 : Create MText Object ;;
;; Returns: -None- ;;
;; Version 1.1 - 2012-04-20 ;;
;; - First release. ;;
;; Version 1.2 - 2015-10-10 ;;
;; - Program updated to account for selection of annotation objects ;;
;; which already contain a field expression. ;;
;; Version 1.3 - 2016-04-10 ;;
;; - Program updated to incorporate UPDATEFIELD command when inserting ;;
;; a field into attribute content. ;;
(defun LM:quickfield ( prop format mode / ent ins obj str )
(if (setq str (LM:quickfield:constructfieldstring prop format))
(cond
((= 1 mode)
(if (setq ent (LM:quickfield:selectifhasprop
"Textstring"
nentsel
(progn
(setq obj (vlax-ename->vla-object ent))
(if (or (= "AcDbMText"
(vlax-get-property obj 'Objectname)
(and
(= "AcDbAttribute"
(= (vlax-get-property obj 'MTextAttribute):vlax-true)
(progn
(setq txt (vla-get-textstring obj))
(vla-put-textstring
obj
(strcat txt "\\P" str)
(if (= "ATTRIB" (cdr (assoc 0 (entget ent))))
(vl-cmdf "_.updatefield" ent "")
( (= 2 mode)
(if (setq ins (getpoint "\nSpecify point for text: "))
(vla-addtext
(vlax-get-property (LM:quickfield:acdoc)
(if (= 1 (getvar 'cvport))
'paperspace
'modelspace
str (vlax-3D-point (trans ins 1 0)) (getvar 'textsize)
( (= 3 mode)
(if (setq ins (getpoint "\nSpecify point for mtext: "))
(vla-addmtext
'paperspace
'modelspace
(vlax-3D-point (trans ins 1 0)) 0.0 str
(princ)
(defun LM:quickfield:selectifhasprop ( prop func / ent )
(while
(progn
(setvar 'errno 0)
(setq ent (car (func (strcat "\nSelect object with " prop " property: "))))
(cond
( (= 7 (getvar 'errno))
(princ "\nMissed, try again.")
( (null ent)
nil
( (not (vlax-property-available-p (vlax-ename->vla-object ent) prop))
(princ (strcat "\nSelected object does not have " prop " property."))
ent
(defun LM:quickfield:acdoc nil
(eval (list 'defun 'LM:quickfield:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
( (lambda nil (vl-load-com)
(eval
(list 'defun 'LM:quickfield:constructfieldstring '( prop format / ent )
(list 'if '(setq ent (LM:quickfield:selectifhasprop prop entsel))
(list 'strcat "%<\\AcObjProp Object(%<\\_ObjId "
(if (vlax-method-applicable-p (vla-get-utility (LM:quickfield:acdoc)) 'getobjectidstring)
(list 'vla-getobjectidstring (vla-get-utility (LM:quickfield:acdoc)) '(vlax-ename->vla-object ent) ':vlax-false)
'(itoa (vla-get-objectid (vlax-ename->vla-object ent)))
">%)." 'prop '(if (/= "" format) (strcat " \\f \"" format "\">%") ">%")
(princ)
;; End of File ;;
