Message 1 of 22
Quick Select Lisp to select all dimensions with same value
08:56 AM
- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
Need to select all the same dimensions with the same dimension style, layer, and value; and then prompt me to override the dimension, which is not necessary a numeric value.
I have been using Quick Select for this task but in most cases I have to work with a lot of dimensions in drawings and is time consuming and repetitive. I have tried the Action recorder and does not go past the command and does not select object type and properties; and I have to enter the numeric value to select all similar dimensions.
Can any help me out with a AutoLisp command that can do all this?
