QUICK REQUEST!!
QUICK REQUEST!!
QUICK REQUEST!!
thanks for helping, I just need this lisp attached to create lines instead of arcs between the objects selected.
Thank you.
(vl-load-com)
(defun C:CB (/ *error* _SortPtListByDist MidObjectsBoundingBox oCMDECHO oOSMODE doc pt pt1 pt2 ptm ptl ss i high sset nextent startentity current_layer)
(defun *error* (errmsg)
(if (not (wcmatch errmsg "Function cancelled,quit / exit abort,console break"))
(princ (strcat "\nError: " errmsg)))
(setvar 'CMDECHO oCMDECHO)
(setvar 'OSMODE oOSMODE)
(vla-endundomark doc)
(princ))
(defun _SortPtListByDist (ptList)
;; Argument: Point list
;; Returns: Point list, sorted by distance from curve
;; By BlackBox
;; http://www.cadtutor.net/forum/showthread.php?61433-Help-Sort-a-list-point-by-distance
(mapcar
'(lambda (x / ptList2)
(setq ptList2 (append (cdr x) ptList2)))
(vl-sort
(mapcar
'(lambda (x / pt ptlist2)
(setq ptlist2
(append
(cons
(vlax-curve-getDistAtPoint
(ssname sspl 0)
(vlax-curve-getClosestPointTo (ssname sspl 0) x T))
x)
ptlist2)))
ptList)
'(lambda (x y)
(< (car x) (car y))))))
(defun MidObjectsBoundingBox (en / Bmin Bmax )
;; Argument: Entity
;; Returns: Point list of centre
(vla-GetBoundingBox (vlax-ename->vla-object en) 'PtArMin 'PtArMax)
(setq Bmin (vlax-safearray->list PtArMin)
Bmax (vlax-safearray->list PtArMax))
(polar Bmin
(angle Bmin Bmax)
(/ (distance Bmin Bmax) 2))
(setq doc (vla-get-activedocument (vlax-get-acad-object)))
(vla-startundomark doc)
(setq oCMDECHO (getvar 'CMDECHO))
(setq oOSMODE (getvar 'OSMODE))
(setvar 'OSMODE 0)
(setq current_layer (getvar "CLAYER"))
(setq startentity (entlast))
(if (and (setq ss (ssget '((0 . "INSERT,CIRCLE,*LINE"))))
(<= 3 (sslength ss))
(= 1 (sslength (setq sspl (ssget "_p" '((0 . "*LINE"))))))
(setq i (sslength ss))
(while (not (minusp (setq i (1- i))))
(if (wcmatch (cdr (assoc 0 (entget (ssname ss i)))) "CIRCLE,INSERT")
(setq pt (MidObjectsBoundingBox (ssname ss i))
ptl (if ptl
(append (list pt) ptl)
(list pt)))
T))
ptl
(setq ptl (_SortPtListByDist ptl)
i 0))
(repeat (1- (length ptl))
(setq pt1 (nth i ptl)
pt2 (nth (1+ i) ptl)
ptm (polar (polar pt1
(angle pt1 pt2)
(/ (distance pt1 pt2) 2))
(+ (angle pt1 pt2) (* pi 0.5)) ;for OPPOSITE BULGE set 1.5 instead of 0.5
(cond (high)
(T (setq high (* (distance pt1 pt2) 0.18)))))) ;change 0.18 for MORE BULGE
(command "_.arc" pt1 ptm pt2)
(setq i (1+ i)))
(princ "\nWrogn selection. Need INSERT, CIRCLE and single *LINE"))
(setq sset (ssadd))
(setq nextent (entnext startentity))
(while (/= nil nextent)
(setq sset (ssadd nextent sset))
(setq nextent (entnext nextent))
(initcommandversion)
(command "join" sset "")
(setvar "CLAYER" current_layer)
(princ)
What I really need is just a lisp that will connect multiple blocks together by a pline from insertion point to insertion point connection each block consecutively to the closest one of the selection.
Moshe-A
@Anonymous  hi,
check this one called BCHAIN. the order goes from left to right and up to down.
note: laying blocks in matrix form will connect the most right block in the row with the first in the row below.
enjoy
moshe
; block chain
(defun c:bchain (/ ss lst) (setvar "cmdecho" 0) (command "._undo" "_begin") (if (setq ss (ssget '((0 . "insert")))) (progn (setq lst (mapcar '(lambda (ename) (cdr (assoc '10 (entget ename))) ) (vl-remove-if 'listp (mapcar 'cadr (ssnamex ss))) ) ); setq (if lst (progn (setq lst (vl-sort (vl-sort lst '(lambda (a0 a1) (< (cadr a0) (cadr a1)))) ; sort in X axis '(lambda (a0 a1) (< (car a0) (car a1))) ; sort in Y axis ) ); setq (command "._pline") (foreach pt lst (command "_none" pt) ) (command "") ); progn ); if ); progn ); if (command "._undo" "_end") (setvar "cmdecho" 1) (princ) ); c:bchain
Thanks Moshe! That is exactly what I needed, works like a charm!
