Burst all blocks in a drawing (without selection set)
I am trying to use Burst Upgraded script By Lee Mac but I wanted to try to get it to burst every single blocks in a drawing and with no selection window(set). Can someone help me? Thanks
This is Brust Upgraded script but Lee Mac
(defun c:pburst nil (LM:burst nil))
(defun c:nburst nil (LM:burst   t))
(defun LM:burst ( nst / *error* )
    (defun *error* ( msg )
        (LM:endundo (LM:acdoc))
        (if (not (wcmatch (strcase msg t) "*break,*cancel*,*exit*"))
            (princ (strcat "\nError: " msg))
        (princ)
    (LM:startundo (LM:acdoc))
    (LM:burstsel
        (LM:ssget "\nSelect blocks to burst: "
            (list "_:L"
                (append '((0 . "INSERT"))
                        (lambda ( / def lst )
                            (while (setq def (tblnext "block" (null def)))
                                (if (= 4 (logand 4 (cdr (assoc 70 def))))
                                    (setq lst (vl-list* "," (cdr (assoc 2 def)) lst))
                            (if lst (list '(-4 . "<NOT") (cons 2 (apply 'strcat (cdr lst))) '(-4 . "NOT>")))
                    (if (= 1 (getvar 'cvport))
                        (list (cons 410 (getvar 'ctab)))
                       '((410 . "Model"))
        nst
    (LM:endundo (LM:acdoc)) (princ)
(defun LM:burstsel ( sel nst / idx )
    (if (= 'pickset (type sel))
        (repeat (setq idx (sslength sel))
            (LM:burstobject (vlax-ename->vla-object (ssname sel (setq idx (1- idx)))) nst)
(defun LM:burstobject ( obj nst / cmd col ent err lay lin lst qaf tmp )
    (if
        (and
            (= "AcDbBlockReference" (vla-get-objectname obj))
            (not (vlax-property-available-p obj 'path))
            (vlax-write-enabled-p  obj)
            (or (and (LM:usblock-p obj)
                     (not (vl-catch-all-error-p (setq err (vl-catch-all-apply 'vlax-invoke (list obj 'explode)))))
                     (setq lst err)
                (progn
                    (setq tmp (vla-copy obj)
                          ent (LM:entlast)
                          cmd (getvar 'cmdecho)
                          qaf (getvar 'qaflags)
                    (setvar 'cmdecho 0)
                    (setvar 'qaflags 0)
                    (vl-cmdf "_.explode" (vlax-vla-object->ename tmp))
                    (setvar 'qaflags qaf)
                    (setvar 'cmdecho cmd)
                    (while (setq ent (entnext ent))
                        (setq lst (cons (vlax-ename->vla-object ent) lst))
                    lst
        (progn
            (setq lay (vla-get-layer    obj)
                  col (vla-get-color    obj)
                  lin (vla-get-linetype obj)
            (foreach att (vlax-invoke obj 'getattributes)
                (if (vlax-write-enabled-p att)
                    (progn
                        (if (= "0" (vla-get-layer att))
                            (vla-put-layer att lay)
                        (if (= acbyblock (vla-get-color att))
                            (vla-put-color att col)
                        (if (= "byblock" (strcase (vla-get-linetype att) t))
                            (vla-put-linetype att lin)
                (if
                    (and
                        (= :vlax-false (vla-get-invisible att))
                        (= :vlax-true  (vla-get-visible   att))
                    (   (if (and (vlax-property-available-p att 'mtextattribute) (= :vlax-true (vla-get-mtextattribute att)))
                            LM:burst:matt2mtext
                            LM:burst:att2text
                        (entget (vlax-vla-object->ename att))
            (foreach new lst
                (cond
                    (   (not (vlax-write-enabled-p new)))
                    (   (= :vlax-false (vla-get-visible new))
                        (vla-delete new)
                    (   t
                        (if (= "0" (vla-get-layer new))
                            (vla-put-layer new lay)
                        (if (= acbyblock (vla-get-color new))
                            (vla-put-color new col)
                        (if (= "byblock" (strcase (vla-get-linetype new) t))
                            (vla-put-linetype new lin)
                        (if (= "AcDbAttributeDefinition" (vla-get-objectname new))
                            (progn
                                (if
                                    (and
                                        (= :vlax-true  (vla-get-constant  new))
                                        (= :vlax-false (vla-get-invisible new))
                                    (   (if (and (vlax-property-available-p new 'mtextattribute) (= :vlax-true (vla-get-mtextattribute new)))
                                            LM:burst:matt2mtext
                                            LM:burst:att2text
                                        (entget (vlax-vla-object->ename new))
                                (vla-delete new)
                            (if nst (LM:burstobject new nst))
            (vla-delete obj)
(defun LM:burst:removepairs ( itm lst )
    (vl-remove-if '(lambda ( x ) (member (car x) itm)) lst)
(defun LM:burst:remove1stpairs ( itm lst )
    (vl-remove-if '(lambda ( x ) (if (member (car x) itm) (progn (setq itm (vl-remove (car x) itm)) t))) lst)
(defun LM:burst:att2text ( enx )
    (entmakex
        (append '((0 . "TEXT"))
            (LM:burst:removepairs '(000 002 003 070 074 100 280 440)
                (subst (cons 73 (cdr (assoc 74 enx))) (assoc 74 enx) enx)
(defun LM:burst:matt2mtext ( enx )
    (entmakex
        (append '((0 . "MTEXT") (100 . "AcDbEntity") (100 . "AcDbMText"))
            (LM:burst:remove1stpairs
                (if (= "ATTDEF" (cdr (assoc 0 enx)))
                   '(001 003 007 010 040 041 050 071 072 073 210)
                   '(001 007 010 040 041 050 071 072 073 210)
                (LM:burst:removepairs '(000 002 011 042 043 051 070 074 100 101 102 280 330 360 440) enx)
            (list (assoc 011 (reverse enx)))
;; Uniformly Scaled Block  -  Lee Mac
;; Returns T if the supplied VLA Block Reference is uniformly scaled
;; obj - [vla] VLA Block Reference
(defun LM:usblock-p ( obj / s )
    (if (vlax-property-available-p obj 'xeffectivescalefactor)
        (setq s "effectivescalefactor")
        (setq s "scalefactor")
    (eval
        (list 'defun 'LM:usblock-p '( obj )
            (list 'and
                (list 'equal
                    (list 'abs (list 'vlax-get-property 'obj (strcat "x" s)))
                    (list 'abs (list 'vlax-get-property 'obj (strcat "y" s)))
                    1e-8
                (list 'equal
                    (list 'abs (list 'vlax-get-property 'obj (strcat "z" s)))
                    1e-8
    (LM:usblock-p obj)
;; entlast  -  Lee Mac
;; A wrapper for the entlast function to return the last subentity in the database
(defun LM:entlast ( / ent tmp )
    (setq ent (entlast))
    (while (setq tmp (entnext ent)) (setq ent tmp))
    ent
;; ssget  -  Lee Mac
;; A wrapper for the ssget function to permit the use of a custom selection prompt
;; msg - [str] selection prompt
;; arg - [lst] list of ssget arguments
(defun LM:ssget ( msg arg / sel )
    (princ msg)
    (setvar 'nomutt 1)
    (setq sel (vl-catch-all-apply 'ssget arg))
    (setvar 'nomutt 0)
    (if (not (vl-catch-all-error-p sel)) sel)
;; Start Undo  -  Lee Mac
;; Opens an Undo Group.
(defun LM:startundo ( doc )
    (LM:endundo doc)
    (vla-startundomark doc)
;; End Undo  -  Lee Mac
;; Closes an Undo Group.
(defun LM:endundo ( doc )
    (while (= 8 (logand 8 (getvar 'undoctl)))
        (vla-endundomark doc)
;; Active Document  -  Lee Mac
;; Returns the VLA Active Document Object
(defun LM:acdoc nil
    (eval (list 'defun 'LM:acdoc 'nil (vla-get-activedocument (vlax-get-acad-object))))
    (LM:acdoc)
(vl-load-com)
(princ
    (strcat
        "\n:: BurstUpgraded.lsp | Version 1.7 | \\U+00A9 Lee Mac "
        (menucmd "m=$(edtime,0,yyyy)")
        " www.lee-mac.com ::"
        "\n:: \"pburst\" to burst primary  |  \"nburst\" to burst primary + nested ::"
(princ)
;;                             End of File                              ;;
I have tried adding this script at the end of his but its not working.
(defun c:burstall (/ ss)
   (repeat 4
      (if (setq ss (ssget "_X" '((0 . "INSERT"))))
         (LM:burst ss)
   (princ)
dlanorh
   (repeat 4
         (LM:burst ss)
   (princ)
The commands have changed
Try adding this to the end and saving, or ensure BurstUpgradedV1-7.lsp is loaded then load the following.
  (LM:burstsel ss t)
  (princ)
And make sure there are no blocks on locked layers
I am not one of the robots you're looking for
