Can someone quickly troubleshoot my code below and see why it wont work? It is modified from another code that does work that essentially does the same thing but makes a pdf. This code is for a very quick print, I removed the filename lines of code and specified a new .pc3 print file to use. I feel like it should work but it doesn't.
(defun c:MWCP (/a b)
(setq a (getpoint "\nPick first corner: "))
(setq b (getcorner a "\nPick opposite corner: "))
(command "tilemode" "1")
(vl-cmdf "-plot"
"Yes"
"Model"
"EngineeringSharpColor.pc3"
"Ledger"
"Inches"
"Landscape"
"No"
"Window"
a
b
"Fit"
"Center"
"Yes"
"KCI-acad.ctb"
"No"
"A"
"No"
"No"
"Yes"
(princ)
