Quick Printing Lisp - Troubleshooting
Jason.Rugg
Jason.Rugg
Can someone quickly troubleshoot my code below and see why it wont work? It is modified from another code that does work that essentially does the same thing but makes a pdf. This code is for a very quick print, I removed the filename lines of code and specified a new .pc3 print file to use. I feel like it should work but it doesn't.
(defun c:MWCP (/a b)
(setq a (getpoint "\nPick first corner: "))
(setq b (getcorner a "\nPick opposite corner: "))
(command "tilemode" "1")
(vl-cmdf "-plot"
"Yes"
"Model"
"EngineeringSharpColor.pc3"
"Ledger"
"Inches"
"Landscape"
"No"
"Window"
a
b
"Fit"
"Center"
"Yes"
"KCI-acad.ctb"
"No"
"A"
"No"
"No"
"Yes"
(princ)
Jason.Rugg
Problem solved, did not have the file saved in the correct location and was conflicting with another copy.
Hi, I copied your codes. and run it, it says "error: too few arguments". I need help.
