- Mark as New
- Bookmark
- Subscribe
- Mute
- Subscribe to RSS Feed
- Permalink
- Report
hi all,
I want to move selected object to a specific layer (by writing its name) and not current one by only using the command line. How would i need to modify this code?
;---------------------------CLAY.LSP------------------------------------------
; by
; BILL CARROLL
; This routine changes entities to the current layer of a drawing.
; It will also switch layers before selecting the entities.
(DEFUN C:82 ()
(SETQ CMDECHO "0")
(PRINT "THIS COMMAND WILL MOVE OBJECTS TO THE CURRENT LAYER.")
(PRINT "PRESS <CTRL-C> TO QUIT")
(TIMING 400) ;Pause
(SETQ CHOICE (GETSTRING "\nCHANGE LAYERS? (Y/cr):"))
(IF (OR (= 89 (ASCII CHOICE)) (= 121 (ASCII CHOICE)))
(CHANGELAY) (CHANGEFUN))
(DEFUN CHANGELAY () ;Function to switch layers
(SETQ OLDLAY (GETVAR "CLAYER"))
(SETQ NEWLAY (GETSTRING "NEXT LAYER :"))
(COMMAND "LAYER" "S" NEWLAY "" )
(CHANGEFUN)
(SETQ MESS "CHANGES DONE, ")
(SETQ CHOICE (GETSTRING "\nRESTORE OLD LAYER? (Y/cr):"))
(RESTORLAY) (SETQ DUMMY () ))
(PRINC MESS)(PRINC "CURRENT LAYER IS : ")(SETQ MESS NEWLAY)
(DEFUN RESTORLAY () ;Function to restore layer
(COMMAND "LAYER" "S" OLDLAY "" )
(SETQ NEWLAY OLDLAY)
(DEFUN CHANGEFUN () ;Function to select and change entities' layers
(SETQ SSET (SSGET)) ;Use Autocad selection set prompt
(SETQ CURRLAY (GETVAR "CLAYER"))
(COMMAND "CHANGE" SSET "" "P" "LA" CURRLAY "") ;Autocad Change command
(SETQ MESS "CHANGED")
(DEFUN TIMING (numtimes) ;Pause loop
(REPEAT numtimes
(1+ 5))
