Qselect macro
Qselect macro
thebeesnees
Qselect macro
thebeesnees
I have created a "clean-up" macro to format external drawings before inserting into our own drawings but need help adding QSELECT functions.
I use QSELECT command to delete all "Point", "Hatch" & "Raster Image" objects from drawings however this proves time consuming when formatting large number of drawings.
Is there a way of automating this with macro/lisp routine?
cadffm
use Lisp, also inside menumacro or script.scr files as well.
The only lisp statement you have to learn is the impressive powerful object selection function: SSGET
You can read all about it in your help and one millions web pages.
If you argue with it, there is a less powerful cui way in Expresstools, command: SSX
Sebastian
cadffm
add. You need to know the real object name to use ssget/ssx
Use this Tool
(defun c:ONAME nil (alert(princ(cdr(assoc 0 (entget(car(entsel)))))))(princ))
Sebastian
thebeesnees
SSGET seems to work. I used the following code:
(setq ss (ssget "_X" '((0 . "HATCH")(410 . "Model"))))
(command "_.erase" ss "")
cadffm
hi,
SSX works too, but ssget is more powerful.
Edit your code, I like to show you why.
1. Open a file with NO toplevel hatchs
   Draw a circle
   Run your code
   What happens?
(command will fire an <ENTER> hit, what will restart the last command (Circle)
2. Draw a hatch
    Jump to another Layout
   Run your code
   What happens?
ERASE can erase objects in the current tab only.
3. Draw a hatch (you are in Layout currently)
   Run your code
   What happens?
(410 . "Model") will select hatchs in MODEL tab only.
change your lines to this:
(if (setq ss (ssget "_X" (list '(0 . "HATCH")(cons 410  (getvar 'CTAB))))) (command "_.erase" ss ""))
It will select all unnested hatchs in the current space and if one or more objects selected, it runs erase.
HTH
Sebastian
Sea-Haven
Another suggestion.
(0 . "HATCH,POINT,IMAGE")
