Lisp to add attribute with field value in dynamic block
francine.zimmermannSRSWJ
I make a lot of block like the attached example and I need time to create the attribut with field value.  I've found a few ideas on the forums, but not exactly what I'm looking for.
The step to create my dynamic block
1. Draw a dynamic block with different parameter, for example B & H
2. By lisp add an attribut: Name-(BxH) B and H are field value
It would save me a lot of time, but is it possible?
For example I found Augi5.lsp but that is linked to a table
cadffm
>>" I need time to create the attribut with field value"
That's not unusual, you need time to draw every line or text too!?
>"By lisp add an attribut: Name-(BxH) B and H are field value"
>"It would save me a lot of time, but is it possible?"
Much time?
Without programming:
Copy the ATTDEF to the clipboard, paste it while in the new block.
Edit the attdef and controle/edit both fields - what needs 5-10secs, depending on if you have to edit one or both.
CTRL+V
doubleclick - attdef
doubleclick - first field (if needed), select the right parameter
doubleclick - second field (if needed), select the right parameter
A tool needs to know the parameter names, if them always the same, it is possible.
"For example I found Augi5.lsp but that is linked to a table"
Augi5 copy the parameter values from a Blockreference to Attributes!
I guess you want to create a default value for an Attdef in a Blockdefinition, what linking to parameters.
Sebastian
I thought a repetitive action could be resolved by a lisp
