Qselect autolisp routine required
avinash00002002
avinash00002002
Hi!
I need Qselect autolisp routine of AutoCAD Qselect command.
Avinash
Kent1Cooper
How should it work differently from just using QSELECT?
Kent Cooper, AIA
paullimapa
You don’t like the dialog box gui with the current Qselect command?
Heres a detailed list of the lisp ssget possibilities from Lee Mac that you can implement on your own.
Paul Li
IT Specialist
@The Office
paullimapa
Ever tried the good old fashion Filter command?
Paul Li
IT Specialist
@The Office
Sea-Haven
You can build your own lisp defun with preset filters or have say pick existing object and make a matching filter. All using (ssget (list (cons 0 objecttype)(cons 8 layer))) and so on.
