Purge Unused Raster Image Reference
GeryKnee
Message 1 of 22
GeryKnee
Hello to everyone.
I come back to my previous "purge all unused AcDbRasterImageDef entities" Post.
Problem ::
 I atach an image for example "C:\Users\Gery\Desktop\ACAD\[Problem]\Purge Unused Raster Image Reference\MyRemovedJpgXRef.jpg"
 I save the drawing document.
 I Quit Autocad
 I Restart Autocad by opening the previous document
 I delete the imade reference. The document now does'n include the image xref object.
 I Quit Autocad
 I export document as DXF format text
 I open the exported DXF
 Opening DXF using notepad
 I see those lines :::
AcDbDictionary
281
1
3
MyRemovedJpgXRef
350
264
0
AcDbRasterImageDef
90
0
1
10
253.0
20
165.0
11
 That is causing many problems with document. Those problems I described in my first post.
 Is there a solution to purge eny LIBRARY REFERENCE to a DELETED XREF REFERENCE as can be purged unsused BLOCK REFERNCED ?????
Gery
Replies (21)
Message 21 of 22
Lott99
@trevor.bird.au Sweet, thank you. It works great. I appreciate you doing it so quickly. Now I can learn more about LISP too when I go through and see what all was modified.
Message 22 of 22
trevor.bird.au
All good, thanks.
I just made the following change to the program:
( (not ImageFile_fqn)
  ;; Image references exist but image file cannot be found.
  (entdel imageref_ename)
);(not ImageFile_fqn)
I originally had (entdel imagedef_ename) but it should be (entdel imageref_ename), although the image reference is deleted either way, but this change is for correctness of the code.
Thanks.
Trevor Bird
