Purge and Audit lisp
Message 1 of 31
Probably a simple lisp request to all of you versed in the language...
I'm looking for an easy lisp which can do the following equivalent keystrokes of commands in one call.
-PU <ENTER>
R <ENTER>
<*> <ENTER>
<N> <ENTER>
-PU <ENTER>
A <ENTER>
<*> <ENTER>
<N> <ENTER>
AUDIT <ENTER>
<Y> <ENTER>
Essentially I have muscle memorized the following in order to purge all registered applications without verifying names, purge all items without verifying names, and audit the drawing and fix all errors detected.
If I could group this into one command it would save on the carpal tunnel and I can easily instill this habit into people to use it as it is very beneficial when it comes to file size and preventing file corruptions from added errors.  If it could group all the result reports of the purges and audits together at the end of the lisp instead of at their sequence points too that would be beneficial but not necessary.
Warren
Replies (30)
Message 21 of 31
maratovich
Use it
https://forums.autodesk.com/t5/visual-lisp-autolisp-and-general/run-audit-command-to-all-the-files-i...
Software development
Automatic creation layouts and viewport. Batch printing drawings from model.
www.kdmsoft.net
Message 22 of 31
maratovich
Use it
www.kdmsoft.net
Message 23 of 31
piyush.parihar24
Sorry That is same file find below attached file
Message 24 of 31
hi thanks a lot it is working,
But have one more problem, I have few files which has faulty objects
when I run audit, It will say as few items have passed and few items fail
For the items failing it will give the Cad handles as shown belowUntitled1.png
Is it not possible, when i run audit the adt file created should display only these faulty Object details as highlighted above
(i don't want the details of passing objects)
Thank You
Message 25 of 31
carloschantre123
Hello
If the report was already created, I think a possible solution would be to use the attached file, which contains a function that reads a text file, takes the required information and saves it in another file.
As in this case what is wanted is to omit the lines that say "Pass", then it could be useful.
With the APPLOAD command, the attached application can be loaded in AutoCAD.
Then, for example, execute the function in the following way:
(LeeArch "C: /BASE/REPORTE.TXT" nil "Pass" "C: /CHO/HOY.TXT" -4)
Where:
- "C: /BASE/REPORTE.TXT" Be the previously obtained report.
-nil It does not have a text or line to start reading, so read from the beginning.
- "Pass" Text that will search in the file lines and will exclude them due to the negative number (-4), if the number is positive, it will leave only the lines with this text.
- "C: /CHO/HOY.TXT" New file that will generate.
This function can be added to the application used to generate the report, and thus not have to do it independently. If the considered one is considered a viable option.
I hope this works.
Message 26 of 31
jrogulski
Do you have version for one file only?
I want to make purge and audit lisp just for one, opened file.
Possibly with extra 'zoom for every layout', 'lock viewport for each layout' and 'check if the scale of viewport is listed on "Scale of selected viewport list" '.
Message 27 of 31
carartur16
Hello
I think the code in Message 7 of this forum can be used to purge and audit an open file.
Another option could be to download the free application: REPAIR
https://apps.autodesk.com/ACD/en/Detail/Index?id=3526209944153209364&appLang=en&os=Win32_64
On the additional points, I'll see how you can do that.
Message 29 of 31
pls.
sent to me file of ( 2. Purge All )
Message 30 of 31
sandipdp
Observer
Observer
PIYUSH ITS UPDATED FINAL LSP FILE FOR USING PURGEAUDITALL COMMAND
Message 31 of 31
sandipdp
Observer
Observer
ITS FINALY UPDATED LISP FILE FOR USING  PURGEAUDIT COMMAND ??
