Text on line lisp
Text on line lisp
will.wydock
Text on line lisp
will.wydock
I am not strong at modifying lisp. I have the routine below, it works fine except that when any type of lines are drawn at an angle over 180 dgrees. Then it puts in text upside down. I know that logically i should have an if statement that says if the angle is 180 or greater that i should subtract 180 to get the angle i should use. Any help would be greatly appreciated.
(vl-load-com)
(defun c:gcs-TextinLine()
(glt-TextinLine 0.09375 )
(princ)
(defun glt-TextinLine (standtext / _cmdecho _osmode lineent lineobj p1 lineangle textheight
textent)
;you need to clear out old variables
;(rtd ) this subroutine converts radians to degrees.
(defun rtd (a) (/ (* a 180.0) pi))
;(dgtr ) this subroutine converts degrees to radians
(defun dtr (a) (* pi (/ a 180.0)))
(setq _cmdecho (getvar "cmdecho"))
;save the user's settings and restore at end
(setvar "cmdecho" 0)
(setq lineent (entsel "\nSelect Line at location of text string"))
;select the line
(setq lineobj (vlax-ename->vla-object (car lineent)))
;get the line object
(setq p1 (cadr lineent))
;get the point where the user clicked
(setq lineangle (rtd (vla-get-angle lineobj)))
;get the angle
(setq textheight (* (getvar "dimscale") standtext))
;calculate the text height
(command ".dtext" "j" "mc" p1 textheight lineangle)
;start the text command
and fill in the values
(while (eq 1 (logand 1 (getvar "CMDACTIVE")))
;wait til the command is no longer active
(command pause)
(setq textent (entlast))
;get the text entity
(command ".trim" textent "" lineent "")
;trim the line using the text
(setvar "cmdecho" _cmdecho)
;restore the user's setting
(princ)
Shneuph
You need to change the ;get the angle line:
(if (> (setq lineangle (cvunit (vla-get-angle lineobj)"radian" "degree")) 180)
  (setq lineangle (- lineangle 180))
);end if
Also cvunit is built in if you don't want to use rtd.  You can even edit a file with the unit names and conversion factors.  I'd have to look that up again where it is.
---sig---------------------------------------
'(83 104 110 101 117 112 104 64 71 109 97 105 108 46 99 111 109)
Shneuph
Actually, that is what you asked for.. but this may get you closer to the outcome you want.
(if (and (> lineangle 90)(< lineangle 270))
(setq lineangle (+ lineangle 180))
);if
Ranjit_Singh
I also prefer that any vertical text is labeled facing to the right. See below fix.
(vl-load-com)
(defun c:gcs-textinline () (glt-textinline 0.09375) (princ))
(defun glt-textinline  (standtext / _cmdecho _osmode lineent lineobj p1 lineangle textheight textent)
 (command ".dtext" "j" "mc" p1 textheight (if (and (>= 270 lineangle) (> lineangle 90)) (- lineangle 180) lineangle))
 (while (eq 1 (logand 1 (getvar "CMDACTIVE"))) (command pause))
 (princ))
