Property limits lines for 3D Model Coordination
cyberflow
Advisor Advisor
Message 1 of 12
cyberflow
Hi everyone,
I'm trying to use my property lines to generate regions and offset them by a specific width, so I can "Union" them with a 3D solid extracted from a Civil 3D surface.
The goal is to bring this into a 3D model coordination viewer, allowing others to visualize and understand the property boundaries in context.
Ultimately, I want to represent the property lines in 3D within the Model Coordination environment.
Is there any tool or LISP routine that can automatically generate a closed shape from a widened polyline?
Frank Freitas
CAE/CAD/BIM Coordinator & Support Specialist
LinkedIn
Replies (11)
Message 2 of 12
RSomppi
Have you considered asking this in the C3D forum?
Message 3 of 12
cyberflow
It's pretty much a autocad question
We're talking about property lines and how to create a closed boundary of a polyline with a width
Frank Freitas
LinkedIn
Message 4 of 12
RSomppi
C3D has some different tools and workflows. I can't say they are helpful for this but the users over there are more likely to have done this exact thing. Just saying...
Message 5 of 12
cyberflow
@RSomppi Will be asking there too then, thanx for that
Will keep this one here too
Frank Freitas
LinkedIn
Message 6 of 12
CodeDing
@cyberflow ,
Can you help me by describing your workflow in simple terms?
Something like:
- User selects closed 3D polyline
- Polyline is offset by XX amount
- Region created from offset polyline
Best,
~DD
Message 7 of 12
autoid374ceb4990
So are you looking for something like this, like a wall around the boundary?
Message 8 of 12
cyberflow
Hi @CodeDing & @autoid374ceb4990
Here's where i'm headed to :
https://youtu.be/KY5yGxtoljQ?si=ELZIO6x8e2DIL7d1&t=433
I want to create a extruded property lines with a little thickness to create afterward a reference with 3D solids of that 3D solid interference so people can visualize in 3D the property lines
I hope my description is clear and please feel free to ask any questions
Frank Freitas
LinkedIn
Message 9 of 12
cyberflow
I think i've found something :
https://www.autodesk.com/support/technical/article/caas/sfdcarticles/sfdcarticles/How-to-convert-lin...
With the Polysolid i was able to extrude the 2d line :
But i'd really like to add a width to that so it outstand more
Frank Freitas
LinkedIn
Message 10 of 12
Sea-Haven
If you have say 2D plines then you can double offset and cap ends then extrude. Here is an example.
(defun c:plcap ( / wid obj obj2 obj3 st1 st2 end1 end2 ent2 ent3 ent4 ent5)
  (setq oldsnap (getvar 'osmode))
  (setvar 'osmode 0)
  (setq wid (getreal "\nEnter width "))
  (setq ht (getreal "\nEnter extrude height "))
  (prompt "Select lines and plines ")
  (setq ss (SSget '((0 . "*line"))))
  (repeat (setq x (sslength ss))
   (setq obj (vlax-ename->vla-object (ssname ss (setq x (1- x)))))
   (vla-offset obj wid)
   (setq obj2 (vlax-ename->vla-object (entlast)))
   (setq st1 (vlax-curve-getstartPoint obj2))
   (setq end1 (vlax-curve-getendPoint obj2))
   (setq ent2 (entlast))
   (vla-offset obj (- wid))
   (setq obj3 (vlax-ename->vla-object (entlast)))
   (setq st2 (vlax-curve-getstartPoint obj3))
   (setq end2 (vlax-curve-getendPoint obj3))
   (setq ent3 (entlast))
   (command "line" st1 st2 "")
   (setq ent4 (entlast))
   (command "line" end1 end2 "")
   (setq ent5 (entlast))
   (command "join" ent2 ent3 ent4 ent5 "")
   (command "extrude" (entlast) "" ht)
  (command "vpoint" "-1,-1,1")
  (setvar 'osmode oldsnap)
  (princ)
(c:plcap)
Message 11 of 12
AVCPlugins
I'm not sure I understand you correctly, but the AVC Zone command will help you create a closed zone around any curve.  The command will make an offset (or 2 offsets in both directions) and close the ends of the lines. The zone can be either a polyline or a region. In both cases, it is not difficult to pull it out into a 3D solid.
Is this a suitable option?
Plugins for AutoCAD
A>V>C>
AppStore | Facebook | Twitter | YouTube | Blog
Message 12 of 12
cyberflow
Thx @Sea-Haven !!
That suggestion works perfectly
Frank Freitas
LinkedIn
