Programming Lisp with AutoCad LT How ?
paul9ZMBV
paul9ZMBV
I'm keen to start learning Lisp programming, but only have AutoCad LT 2025
I understand the Visual Lisp isn't available in LT, whats my best option ?
Also any links to a beginners guide would be great
Any help much appreciated
Kind regards
Paul
paullimapa
Whoever told you visual lisp is not available in LT 2025 is wrong.
Try the examples on here:
https://www.autodesk.com/blogs/autocad/autocad-lt-2024-autolisp/#:~:text=One%20of%20the%20most%20imp....
You can use notepad ++ or VS Code and install the LISP extensions to assist you in writing code:
https://code.visualstudio.com/docs?dv=win
This is a great website to learn Lisp:
https://www.afralisp.net/
Paul Li
IT Specialist
@The Office
Sea-Haven
Lisp was introduced with LT 2024, its not a full version some options are not available, but most useable ones are. Plenty of help can be found here.
Google is your friend and use words to describe a task make sure you add "Autocad Lisp" when searching.
pendean
Community Legend
Community Legend
@paul9ZMBV wrote:
...have AutoCad LT 2025...
Have you explored the links in HELP in your program to get started yet
https://help.autodesk.com/view/ACDLT/2025/ENU/?guid=GUID-FB2F8870-8CC0-4062-AA06-9D2893F8E09E
