Adding an vertex to existing polyline
dmitri_alyvajev
dmitri_alyvajev
Community Visitor
Community Visitor
Hello everyone.
I have difficulties with writing LISP for adding vertex to existing polyline.
There is polyline with many vertices and there are known points, which are located on segments of polyline.
I need to make a LISP for adding vertex in all these points.
Below are two pictures, which illustrate the task.
Circle center points are located right on the polyline.
Which steps I have to make to achieve next result>>
Thank you in advance!!!
Moshe-A
@dmitri_alyvajev  hi,
You say you have difficulties? show us 🙏
it's more easy to draw a new pline on top (delete the existing) instead of editing after selecting the pline + 2 circles.
Moshe
ВeekeeCZ
Here's a sub that should help. It's from Lee Mac or mostly.
(defun c:test ( / e p)
;; From Lee Mac's code
(defun :PAddVertex (e p / tan LM:LWVertices a b e h l n r w x z)
  (defun tan ( x ) (if (not (equal 0.0 (cos x) 1e-10)) (/ (sin x) (cos x))))
  (defun LM:LWVertices ( e )
    (if (setq e (member (assoc 10 e) e))
      (cons (list (assoc 10 e)
		  (assoc 40 e)
		  (assoc 41 e)
		  (assoc 42 e))
	    (LM:LWVertices (cdr e)))))
  (if (and p
	   e
	   (setq p (vlax-curve-getclosestpointto e (trans p 1 0))
		 n (vlax-curve-getparamatpoint e p))
    (if (not (equal n (fix n) 1e-8))
      (progn
	(setq e (entget e)
	      h (reverse (member (assoc 39 e) (reverse e)))
	      l (LM:LWVertices e)
	      z (assoc 210 e)
	(repeat (fix n)
	  (setq a (cons (car l) a)
		l (cdr l)))
	(setq x (car l)
	      r (- n (fix n))
	      w (cdr (assoc 40 x))
	      w (+ w (* r (- (cdr (assoc 41 x)) w)))
	      b (atan (cdr (assoc 42 x)))
	(entmod
	  (append h
		  (apply 'append (reverse a))
		  (list
		    (assoc 10 x)
		    (assoc 40 x)
		    (cons  41 w)
		    (cons  42 (tan (* r b)))
		  (list
		    (cons  10 (trans p 0 (cdr z)))
		    (cons  40 w)
		    (assoc 41 x)
		    (cons  42 (tan (* (- 1.0 r) b)))
		  (apply 'append (cdr l))
		  (list z)))))))
  (if (setq e (car (entsel "Polyline:")))
    (while (setq p (getpoint "Point: "))
      (:PAddVertex e p)))
  (princ)
Sea-Haven
Why not use Pedit has a add vertex option !
: PEDIT
Select polyline to edit [Multiple]:
Edit polyline [Edit vertices/Close/Decurve/Fit/Join/Linetype mode/Reverse direction/Spline/Taper/Width/Undo] <eXit>: E
Edit vertices [Next vertex/Previous vertex/Angle/Break/Insert vertex/Move/Regen/SElect/Straighten/Tangent/Width/eXit]: I
Location for new vertex:
