Probleme with slide dimensions in DCL
Kh.mbkh
Kh.mbkh
Hello!
As shown in the picture, even I use reels dimensions of my slide  "(dimx_tile   &  dimy_tile ); the image is soo small !!
My DCL code:
: image { key = "MS"; height = 30; fixed_height = true; width = 60; fixed_width = true; color = 0; aspect_ratio = 1;
is_enabled = false; is_tab_stop = false; }
My lisp:
(start_image "MS")
(slide_image 0 0 (- (dimx_tile "MS") 0) (- (dimy_tile "MS") 0) Fil) ; (dimx_tile "MS") should be in Pixels
(end_image)
Any idea !!
john.uhden
It's probably all in the view during the slide creation.  Slide files are pretty dumb, so manipulation is minimal if at all.
John F. Uhden
Sea-Haven
Like John make the slide as big as you possibly can also RIBBONCLOSE the ribbon seems to reduce vertical size also, use Z C and a scale try a few different numbers bigger and smaller dont forget VSLIDE to check.
Ps for those panicking "RIBBON"
