Visual LISP, AutoLISP and General Customization
Problem with changing the value of an attribute
6 REPLIES 6
313 Views, 6 Replies
Im changing the value of an attribute this way (progn (setq el2 (subst (cons 1 ts1) (assoc 1 el2) el2)) (entmod el2) (entupd (cdar el2))) Sometimes it works an somtimes not. Can someone tell me why? The result of subst is okay but entmod and entupd doesn't seem te have affect on it. MJ
6 REPLIES 6
You are likely mixing ActiveX and vanilla AutoLISP (in A2k2 and earlier, have not verified in A2k4/5). Search a few years back in this ng on this topic for more details. -- R. Robert Bell "Marcel Janmaat" wrote in message news:4087ced6$1_3@newsprd01... Im changing the value of an attribute this way (progn (setq el2 (subst (cons 1 ts1) (assoc 1 el2) el2)) (entmod el2) (entupd (cdar el2))) Sometimes it works an somtimes not. Can someone tell me why? The result of subst is okay but entmod and entupd doesn't seem te have affect on it. MJ
Try:
(progn
(entmod (setq el2 (subst (cons 1 ts1) (assoc 1 el2) el2)))
(entupd el2)
Bob
Are the ones that don't update on locked layers? "Marcel Janmaat" wrote in message news:4087ced6$1_3@newsprd01... > > Im changing the value of an attribute this way > > (progn (setq el2 (subst (cons 1 ts1) (assoc 1 el2) el2)) (entmod el2) > (entupd (cdar el2))) > > Sometimes it works an somtimes not. Can someone tell me why? > > The result of subst is okay but entmod and entupd doesn't seem te have > affect on it. > > MJ > >
bob.at
Marcel,
give the following change a chance:
(entupd (cdr (assoc -1 el2))))
bob.at
bbowman8E7LC
Same problem here. Such an old thread I imagine there was a solution somewhere...
Kent1Cooper
in reply to: bbowman8E7LC
I would switch to the newer (setpropertyvalue) world [which didn't exist when this topic began], in which the Tag of an Attribute constitutes a "property" of the Block insertion:
(setpropertyvalue BlockEntityName "TagName" "NewValue")
Kent Cooper, AIA
AutoCAD Inside the Factory
