Print to wire label printer
Hello everyone, I am not sure if this is the correct forum to place this question or not, but I have a question about printing from AutoCAD to a thermal printer, to create wire labels.
The company I work for is going to purchase a thermal printer to print out wire labels (Heat shrink labels).
The "wire label" text will be from a wiring diagram that I produce.
The thermal printer has a software that imports excel spreadsheet to print from.
So my question is, what would be the best way to get my wiring diagram wire text into a spreadsheet.
I use standard AutoCAD, not AutoCAD electrical, by the way.
I know there are LISP routines that will take your text and put them in a spreadsheet, but I was wanting to know if AutoCAD has some other built in capabilities for this.
oscardosanjos
Did you already tried to use attributes to do that? If I understand properly, why don't you create blocks and insert into them some attributes with the desired information and after that you extract that data?
Thanks for your reply. That is a good thought and I would probably try it, but it the meantime, I found an APP that allows me to extract the text into Excel. Now, my problems are solved. Thanks again
