Preview for Polyline root.
smallƑish
Message 1 of 48
smallƑish
For example, User picks 2 Points, we have 2 options to connect the 2 points with the orthogonal root.
lisp is here;
(defun c:1 ( / Z1 z2 z5 z6 z3 z4)
  (if (and (setq Z1 (getpoint "\n Top of L shape : "))
	   (setq z2 (getpoint Z1 "\n Bot of L shape : "))
	   (setq z3 (list (car Z1) (cadr z2) 0.))
	   (setq z6 (list (car z2) (cadr Z1) 0.))
	   (setq z4 (inters Z1 (polar Z1 (* 1.75 pi) 1.)
			    z3 z2 nil))
	   (setq z5 (inters z2 (polar z2 (* 1.75 pi) 1.)
			    Z1 z6 nil))
    (command "_.line" "_non" Z1 "_non" z3 "_non" z2 ""))
  (princ)
(defun c:2 ( / Z1 z2 z5 z6 z3 z4)
  (if (and (setq Z1 (getpoint "\nTop of 7 shape: "))
	   (setq z2 (getpoint Z1 "\n Bot of 7 shape: "))
			    z3 z2 nil))
			    Z1 z6 nil))
    (command "_.line" "_non" Z1 "_non" z6 "_non" z2 ""))
  (princ)
Any chance to preview option 1 and option 2 Before making the polyline ?
Replies (47)
Message 41 of 48
viejaytabago02
Hi sir,
Im interested in this lisp, but how about that it is automatically fillet the intersection point and choose the value of the fillet, for example? 30mm or 40mm? Thank you
Message 42 of 48
Kent1Cooper
@viejaytabago02 wrote:
.... how about that it is automatically fillet the intersection point and choose the value of the fillet, for example? 30mm or 40mm? Thank you
That is probably possible, but first:  Which of several of my routines in this topic?
Kent Cooper, AIA
Message 43 of 48
viejaytabago02
For last routine lisp sir if we are able to have a fillet option for the intersection lines and radius option. Thank yo
Message 44 of 48
Kent1Cooper
.... if we are able to have a fillet option for the intersection lines and radius option. Thank yo
Well, I played with it for a while, and came up with the attached Path2Points.lsp, defining a P2P command.  I think it does everything, in limited trial.  See the comments at the top of the file.
EDIT:  File replaced 1 July 2024 with a correction.
Kent Cooper, AIA
Message 45 of 48
viejaytabago02
It work's, Thank you so much sir @Kent1Cooper for sharing.
Message 46 of 48
viejaytabago02
It work's, Thank you so much sir @Kent1Cooper for sharing. May The Lord Jesus Bless you
Message 47 of 48
nada_rathakrishnan4ZKGD
Dear Cooper
The U length (same as other) and orthogonal are now working for me
All others shapes are working
Opposite end/corner: <Ortho on>
Error: bad argument type: stringp ("L,Z,D")
Message 48 of 48
Kent1Cooper
@nada_rathakrishnan4ZKGD wrote:
....Opposite end/corner: <Ortho on>
I don't know how this line of code ended up the way it did, but it slipped through my trials.  Change this line:
(if (and orth (wcmatch *P2Pshape* '("L,Z,D")))
by removing the red parts, to just this:
(if (and orth (wcmatch *P2Pshape* "L,Z,D"))
I replaced the file in Message 44 with a corrected version.
Kent Cooper, AIA
