HOW TO I REMOVE DUPLIACTE OR OVERRIDE WITH POLYLINE SAME LAYER NAME OBJECT I ATTACH THE FILE IN DETAIL
This task is too good , for everyone on public., Please you sell more items, you make more money$ on your jobs, and you hire anyone for yourtask=duplicate polyline, you hire per money$(minim >=100$).
In this way= you save the future of AutoCad, Briscad, Zwcad. The godness Autodesk, need more job/s exchange to money.
How about command Overkill
https://help.autodesk.com/view/ACDLT/2023/ENU/?guid=GUID-44B9ECFC-752C-4CC5-9DA3-84DBF3B17CA6
Yes, OVERKILL, and specifically, in its dialog box after selecting items, un-check the Layer property, meaning "do not ignore the Layer, but take it into consideration, in determining whether objects duplicate each other."
That way, the ones on different Layers will not be considered as coinciding, and only a duplicate on the same Layer as a coinciding object will be removed.
