possible to create DCL menu will be work above autocad ?
E.S.7.9
E.S.7.9
hi everybody
i want to create a DCL menu which will be work above autocad all the time until i choose to close it..
somebody can share with me simple DCL code to get understanding the idea if it is possible ?
thank you for answers
roland.r71
Afaik, you can not have a DCL dialog open AND continue working with AutoCAD.
Everything is "locked" except for the dialog as the system is waiting for it to close. (the dialog check is actually an endless loop inside your lisp, which can (only) end if certain conditions are met.)
doaiena
It's not possible to create such a dialog with DCL. I would suggest you check out OpenDCL. It has both a GUI, used to create your dialogs and a runtime env. for AutoCAD.
