The main key is subfunction (Listclockwise-p ptlst)...
Here is something based on it (if it's not exactly what you're looking for) :
(defun c:setplsplhelclockw ( / unit mxv v^v transptucs transptwcs 3dplv hplv ohplv lplv olplv splv helv ListClockwise-p
ss cmde i c ch ent l ll clw
(defun unit ( v )
(mapcar '(lambda ( x ) (/ x (distance '(0.0 0.0 0.0) v))) v)
(defun mxv ( m v )
(mapcar '(lambda ( r ) (apply '+ (mapcar '* r v))) m)
(defun v^v ( u v )
(mapcar '(lambda ( n ) (- (* (nth (car n) u) (nth (cadr n) v)) (* (nth (cadr n) u) (nth (car n) v)))) '((1 2) (2 0) (0 1)))
(defun transptucs ( pt p1 p2 p3 / ux uy uz )
(setq uz (unit (v^v (mapcar '- p2 p1) (mapcar '- p3 p1))))
(setq ux (unit (mapcar '- p2 p1)))
(setq uy (unit (mapcar '- p3 p1)))
(mxv (list ux uy uz) (mapcar '- pt p1))
(defun transptwcs ( pt pt1 pt2 pt3 / pt1n pt2n pt3n )
(setq pt1n (transptucs '(0.0 0.0 0.0) pt1 pt2 pt3))
(setq pt2n (transptucs '(1.0 0.0 0.0) pt1 pt2 pt3))
(setq pt3n (transptucs '(0.0 1.0 0.0) pt1 pt2 pt3))
(transptucs pt pt1n pt2n pt3n)
(defun 3dplv ( pl / v vl )
(if (and (eq (cdr (assoc 0 (entget pl))) "POLYLINE") (< 7 (cdr (assoc 70 (entget pl))) 14))
(progn
(setq v pl)
(while (eq (cdr (assoc 0 (entget (setq v (entnext v))))) "VERTEX")
(setq vl (cons (cdr (assoc 10 (entget v))) vl))
(reverse vl)
(progn
(prompt "\nNot valid pl agument supplied to function")
(princ)
(defun hplv ( pl / el uz v vl ux uy )
(if (and (eq (cdr (assoc 0 (entget pl))) "POLYLINE") (< -1 (cdr (assoc 70 (entget pl))) 6))
(progn
(setq el (last (cdr (assoc 10 (entget pl)))))
(setq uz (cdr (assoc 210 (entget pl))))
(setq v pl)
(setq vl (cons (list (car (cdr (assoc 10 (entget v)))) (cadr (cdr (assoc 10 (entget v)))) el) vl))
(if (equal uz '(0.0 0.0 1.0) 1e-8) (setq ux '(1.0 0.0 0.0) uy '(0.0 1.0 0.0)))
(if (equal uz '(0.0 0.0 -1.0) 1e-8) (setq ux '(-1.0 0.0 0.0) uy '(0.0 1.0 0.0)))
(if (not (or (equal uz '(0.0 0.0 1.0) 1e-8) (equal uz '(0.0 0.0 -1.0) 1e-8))) (setq ux (unit (v^v '(0.0 0.0 1.0) uz))))
(if (not uy) (setq uy (unit (v^v uz ux))))
(setq vl (mapcar '(lambda ( p ) (transptwcs p '(0.0 0.0 0.0) ux uy)) vl))
(reverse vl)
(progn
(princ)
(defun ohplv ( pl / v vl )
(progn
(setq v pl)
(reverse vl)
(progn
(princ)
(defun lplv ( pl / el uz vl ux uy )
(if (eq (cdr (assoc 0 (entget pl))) "LWPOLYLINE")
(progn
(setq el (cdr (assoc 38 (entget pl))))
(setq vl (mapcar 'cdr (vl-remove-if-not '(lambda ( p ) (= (car p) 10)) (entget pl))))
(setq vl (mapcar '(lambda ( p ) (list (car p) (cadr p) el)) vl))
vl
(progn
(princ)
(defun olplv ( pl / vl )
(progn
vl
(progn
(princ)
(defun splv ( spl / vl )
(if (eq (cdr (assoc 0 (entget spl))) "SPLINE")
(progn
(setq vl (mapcar 'cdr (vl-remove-if-not '(lambda ( p ) (= (car p) 10)) (entget spl))))
vl
(progn
(prompt "\nNot valid spl agument supplied to function")
(princ)
(defun helv ( hel / vl )
(if (eq (cdr (assoc 0 (entget hel))) "HELIX")
(progn
(setq vl (mapcar 'cdr (vl-remove-if-not '(lambda ( p ) (= (car p) 10)) (entget hel))))
vl
(progn
(prompt "\nNot valid hel agument supplied to function")
(princ)
(defun ListClockwise-p (lst / z vlst)
(vl-catch-all-apply 'minusp
(list
(if
(not
(equal 0.0
(setq z
(apply '+
(mapcar
(function
(lambda (u v)
(- (* (car u) (cadr v)) (* (car v) (cadr u)))
(setq vlst
(mapcar
(function
(lambda (a b) (mapcar '- b a))
(mapcar (function (lambda (x) (car lst))) lst)
(cdr (reverse (cons (car lst) (reverse lst))))
(cdr (reverse (cons (car vlst) (reverse vlst))))
) 1e-6
z
(progn
(prompt "\n\nChecked vectors are colinear - unable to determine clockwise-p of list")
nil
(prompt "\nSelect 2DPOLYLINES, 3DPOLYLINES, SPLINES and HELIXES for setting CW/CCW direction")
(setq ss (ssget "_:L" '((0 . "POLYLINE,LWPOLYLINE,SPLINE,HELIX"))))
(setq cmde (getvar 'cmdecho))
(setvar 'cmdecho 0)
(setq i -1)
(initget "CW CCW")
(setq c (getkword "\nSet 2DPOLYLINES, 3DPOLYLINES, SPLINES and HELIXES clock-wise / counter-clock-wise ( CW / CCW ) <CW> : "))
(if (eq c "CCW")
(progn
(initget "UCS OCS")
(setq ch (getkword "\nSet 3DPOLYLINES, SPLINES, HELIXES clockwise viewed from UCS and 2DPOLYLINES viewed from (UCS / OCS) <OCS> : "))
(if (eq ch "UCS")
(progn
(while (setq ent (ssname ss (setq i (1+ i))))
(cond
( (and (eq (cdr (assoc 0 (entget ent))) "POLYLINE") (< 7 (cdr (assoc 70 (entget ent))) 14))
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (3dplv ent)))) T)
(progn
(command "_.reverse" ent "")
(if (assoc "3DPOLYLINE" l)
(setq l (subst (cons "3DPOLYLINE" (1+ (cdr (assoc "3DPOLYLINE" l)))) (assoc "3DPOLYLINE" l) l))
(setq l (cons (cons "3DPOLYLINE" 1) l))
(progn
(if (vl-catch-all-error-p clw)
(if (assoc "3DPOLYLINE" ll)
(setq ll (subst (cons "3DPOLYLINE" (1+ (cdr (assoc "3DPOLYLINE" ll)))) (assoc "3DPOLYLINE" ll) ll))
(setq ll (cons (cons "3DPOLYLINE" 1) ll))
( (and (eq (cdr (assoc 0 (entget ent))) "POLYLINE") (< -1 (cdr (assoc 70 (entget ent))) 6))
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (hplv ent)))) T)
(progn
(if (assoc "HEAVY2DPOLYLINE" l)
(setq l (subst (cons "HEAVY2DPOLYLINE" (1+ (cdr (assoc "HEAVY2DPOLYLINE" l)))) (assoc "HEAVY2DPOLYLINE" l) l))
(setq l (cons (cons "HEAVY2DPOLYLINE" 1) l))
(progn
(if (assoc "HEAVY2DPOLYLINE" ll)
(setq ll (subst (cons "HEAVY2DPOLYLINE" (1+ (cdr (assoc "HEAVY2DPOLYLINE" ll)))) (assoc "HEAVY2DPOLYLINE" ll) ll))
(setq ll (cons (cons "HEAVY2DPOLYLINE" 1) ll))
( (eq (cdr (assoc 0 (entget ent))) "LWPOLYLINE")
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (lplv ent)))) T)
(progn
(if (assoc "LIGHTWEIGHT2DPOLYLINE" l)
(setq l (subst (cons "LIGHTWEIGHT2DPOLYLINE" (1+ (cdr (assoc "LIGHTWEIGHT2DPOLYLINE" l)))) (assoc "LIGHTWEIGHT2DPOLYLINE" l) l))
(setq l (cons (cons "LIGHTWEIGHT2DPOLYLINE" 1) l))
(progn
(if (assoc "LIGHTWEIGHT2DPOLYLINE" ll)
(setq ll (subst (cons "LIGHTWEIGHT2DPOLYLINE" (1+ (cdr (assoc "LIGHTWEIGHT2DPOLYLINE" ll)))) (assoc "LIGHTWEIGHT2DPOLYLINE" ll) ll))
(setq ll (cons (cons "LIGHTWEIGHT2DPOLYLINE" 1) ll))
( (eq (cdr (assoc 0 (entget ent))) "SPLINE")
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (splv ent)))) T)
(progn
(if (assoc "SPLINE" l)
(setq l (subst (cons "SPLINE" (1+ (cdr (assoc "SPLINE" l)))) (assoc "SPLINE" l) l))
(setq l (cons (cons "SPLINE" 1) l))
(progn
(if (assoc "SPLINE" ll)
(setq ll (subst (cons "SPLINE" (1+ (cdr (assoc "SPLINE" ll)))) (assoc "SPLINE" ll) ll))
(setq ll (cons (cons "SPLINE" 1) ll))
( (eq (cdr (assoc 0 (entget ent))) "HELIX")
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (helv ent)))) T)
(progn
(if (assoc "HELIX" l)
(setq l (subst (cons "HELIX" (1+ (cdr (assoc "HELIX" l)))) (assoc "HELIX" l) l))
(setq l (cons (cons "HELIX" 1) l))
(progn
(if (assoc "HELIX" ll)
(setq ll (subst (cons "HELIX" (1+ (cdr (assoc "HELIX" ll)))) (assoc "HELIX" ll) ll))
(setq ll (cons (cons "HELIX" 1) ll))
(progn
(cond
(progn
(progn
(if (eq (setq clw (ListClockwise-p (ohplv ent))) T)
(progn
(progn
(if (eq (setq clw (ListClockwise-p (olplv ent))) T)
(progn
(progn
(progn
(progn
(progn
(progn
(progn
(initget "UCS OCS")
(setq ch (getkword "\nSet 3DPOLYLINES, SPLINES clockwise viewed from UCS and 2DPOLYLINES viewed from (UCS / OCS) <OCS> : "))
(if (eq ch "UCS")
(progn
(cond
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (3dplv ent)))) nil)
(progn
(progn
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (hplv ent)))) nil)
(progn
(progn
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (lplv ent)))) nil)
(progn
(progn
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (splv ent)))) nil)
(progn
(progn
(if (eq (setq clw (ListClockwise-p (mapcar '(lambda ( p ) (trans p 0 1)) (helv ent)))) nil)
(progn
(progn
(progn
(cond
(progn
(progn
(if (eq (setq clw (ListClockwise-p (ohplv ent))) nil)
(progn
(progn
(if (eq (setq clw (ListClockwise-p (olplv ent))) nil)
(progn
(progn
(progn
(progn
(progn
(progn
(foreach e l
(prompt "\n\nTotal reversement in ") (if (eq c "CCW") (prompt "counter-clock-wise direction of \"") (prompt "clock-wise direction of \"")) (prompt (car e)) (prompt "\" entity(ies) is(are) : ") (princ (itoa (cdr e)))
(prompt "\n")
(foreach e ll
(prompt "\nTotal unknown direction of vertices - no reversement processed of \"") (prompt (car e)) (prompt "\" entity(ies) is(are) : ") (princ (itoa (cdr e)))
(setvar 'cmdecho cmde)
(princ)
(defun c:sclw nil (c:setplsplhelclockw))
HTH, M.R.
Marko Ribar, d.i.a. (graduated engineer of architecture)
