polyline creation into table
Can someone create or refer me to a .lsp script that will add all similar polylined item to display in AutoCAD in the form of a table.
The table needs to show the pattern inside of the polyline, the layer name and the total Square footage of the similar patterns.
I have been doing this but one mistake make the process incorrect. I am looking to automate the process without purchasing a CAFM software package.
Below is what I wish the table to look like and I need it to be dynamic so changes i make are immediately reflected in the table.
Thank you.
Slawomir_
Hi!
This thread is somewhat similar. Maybe you will find answer there.
DATAEXTRACTION command could also be helpful.
Slawomir_
Hi, have you found solution for your question?
I have not found a solution.
