Notice: Upload of PDF documents is currently unavailable across the Community due to an ongoing issue.
Polyline autodim lisp editting
holyhexor0o0
Message 1 of 8
holyhexor0o0
Hi all, I found this great lisp that does all the things needed,however there is a slight problem of the dim distance.
The distance is set in the script as
(* 3(getvar "DIMTXT")))
which is 3 times the Dim txt height. Every time that a different drawing needs a different distance, the script needs to be  changed
Can anyone edit this so it would jump out a prompt and we can type out the distance ourselves, or type out the type out the X amount of times of Dim txt height or smth.
Accepted solutions (3)
Replies (7)
Message 2 of 8
komondormrex
hey,
maybe like that
(defun c:pdim(/ plSet pLlst vLst oldOsn cAng cDis cPt times)
 (if (null init_list) (setq init_list '(3)))
 (princ "\n<<< Select LwPolyline for dimensioning >>> ")
 (if(setq plSet(ssget '((0 . "LWPOLYLINE"))))
   (progn
     (setq pLlst(vl-remove-if 'listp
                        (mapcar 'cadr(ssnamex plSet)))
    oldOsn(getvar "OSMODE")
	 times (getint (strcat "Times DimTxt dimension distance <" (itoa (nth 0 init_list)) ">: "))
	 times (if (null times) (nth 0 init_list) times)
    ); end if
     (setvar "OSMODE" 0)(setvar "CMDECHO" 0)
     (command "_.undo" "_be")
     (foreach pl pLlst
(setq vLst(mapcar '(lambda(x)
	   (trans x 0 1))(mapcar 'cdr
	     (vl-remove-if-not
	       '(lambda(x)(= 10(car x)))(entget pl))))
      ); end setq
(if(equal '(70 . 1)(assoc 70(entget pl)))
  (setq vLst(append vLst(list(car vLst))))
  ); end if
(while(< 1(length vLst))
  (setq cAng(angle(car vLst)(cadr vLst))
        cDis(/(distance(car vLst)(cadr vLst))2))
  (if(>=(caar vLst)(caadr vLst))
    (setq cAng(- cAng pi))
    ); end if
  (setq cPt(polar
	     (polar(car vLst)cAng cDis)
	     (+ cAng(* 0.5 pi))(* times (getvar "DIMTXT")))
	); end setq
  (command "_.dimaligned"(car vLst)(cadr vLst) cPt)
  (setq vLst(cdr vLst))
  ); end while
); end foreach
     (command "_.undo" "_e")
     (setvar "OSMODE" oldOsn)(setvar "CMDECHO" 1)
	 (setq init_list (list times))
     ); end progn
   ); end if
 (princ)
Message 3 of 8
holyhexor0o0
thanks, it sure works
Message 4 of 8
holyhexor0o0
Hi komondormrex,
First of all, thank you very much for your help. This Lisp is well used by my colleagues.
However the distance is sometimes a problem because it requires value of an interger.
Could you please edit this lisp to enter absolute number instead ?
Message 5 of 8
komondormrex
hey there,
sure
 (if (null init_list) (setq init_list '(3.0)))
   (progn
	 times (getreal (strcat "Times DimTxt dimension distance <" (rtos (nth 0 init_list) 2 1) ">: "))
    ); end if
     (foreach pl pLlst
	     (vl-remove-if-not
      ); end setq
  ); end if
    ); end if
  (setq cPt(polar
	); end setq
  ); end while
); end foreach
     ); end progn
   ); end if
 (princ)
Message 6 of 8
holyhexor0o0
Thank you it works with non interger numbers now, however sorry for not making myself clear.
What i meant regarding "absolute number" it the number where you offset from polyline, not the number of "multiple for text height".
E.G Dimal 4 units from polyline (instead of 2 times of text height 2)
Message 7 of 8
komondormrex
sorry, the following uses absolute dimension offset number.
(defun c:pdim (/ plSet pLlst vLst oldOsn cAng cDis cPt offset)
	(if (setq plSet(ssget '((0 . "LWPOLYLINE"))))
	 	(progn
	 	  	(setq pLlst (vl-remove-if 'listp (mapcar 'cadr (ssnamex plSet)))
	 	  	 	  oldOsn (getvar "OSMODE")
	 	  	  	  offset (getreal (strcat "Absolute dimension offset distance <" (rtos (nth 0 init_list) 2 1) ">: "))
	 	  	  	  offset (if (null offset) (nth 0 init_list) offset)
	 	  	); end if
	 	  	(setvar "OSMODE" 0)
	 	  	(foreach pl pLlst
				(setq vLst (mapcar '(lambda(x) (trans x 0 1))
								   (mapcar 'cdr (vl-remove-if-not '(lambda(x) (= 10 (car x))) (entget pl)))
	 	  		); end setq
				(if (equal '(70 . 1) (assoc 70 (entget pl)))
	 	 		); end if
				(while (< 1 (length vLst))
	 	 			(setq cAng (angle (car vLst) (cadr vLst))
	 	  				  cDis (/ (distance(car vLst) (cadr vLst))2)
	 	 			(if	(>=	(caar vLst)	(caadr vLst))
	 	  				(setq cAng (- cAng pi))
	 	  			); end if
	 	 			(setq cPt (polar (polar (car vLst) cAng cDis)
	 	  					     	 (+ cAng (* 0.5 pi))
									 offset
	 	  			); end setq
	 	 			(command "_.dimaligned" (car vLst ) (cadr vLst) cPt)
	 	 		); end while
			); end foreach
	 	  	(setq init_list (list offset))
	 	  ); end progn
	); end if
 	(princ)
Message 8 of 8
holyhexor0o0
Thank you very much mister superman
