Points is section view appearing in profile view
jmu34
jmu34
Hello @Jeff_M and @cwr001,
I read a previous post where you created a Lisp that allows placing a point in a section view, and it simultaneously appears in the plan view.  Is there a similar function for use between section view and profile view? Specifically, I want to place a point in the section view and have it simultaneously projected onto the profile view.
Thanks for the help
hosneyalaa
Can you attached example drawing
jmu34
I have attached a sample file.
I would like to create a cogo point in section view and have it simultaneously appear/projected on profile view.
@hosneyalaa
@Jeff_M
@cwr001
Thanks for the help.
paullimapa
Sea-Haven
Just a suggestion when you use Civil Site Design a civil package as you move the cursor in the vertical road design it shows the location in the plan view, you would have say 3 views open, the Plan, long section & cross sections, all 3 are dynamically linked, change a vertical level and the cross sections up date at same time. Yes it has a cost but in terms of production time saving, cost will be recouped.
