Points from a list
Points from a list
carlos_m_gil_p
Points from a list
carlos_m_gil_p
Hello boys how are you.
They could help me with a list of points.
I have a list of points extracted from drawn rectangles.
From that list of points, I need to extract the lower left point and the upper right point.
Example one:
Original list ((1.0 1.0) (5.5 1.0) (5.5 4.0) (1.0 4.0))
Result ((1.0 1.0) (5.5 4.0))
Example two:
Original list ((15.5 9.0) (11.0 9.0) (11.0 6.0) (15.5 6.0))
Result ((15.5 9.0) (11.0 6.0))
Thank you.
Excuse my English, I only speak Spanish.
AutoCAD 2026
Visual Studio Code 1.99.3
AutoCAD AutoLISP Extension 1.6.3
Windows 10 (64 bits)
ronjonp
Are your rectangles all orthogonal ? If so use the boundingbox method:
(if (setq e (car (entsel)))
  (progn (vla-getboundingbox (vlax-ename->vla-object e) 'll 'ur)
	 (mapcar 'vlax-safearray->list (list ll ur))
Or use this for your point list ... although it's still the bounding box.
(setq l '((1.0 1.0) (5.5 1.0) (5.5 4.0) (1.0 4.0)))
(list (apply 'mapcar (cons 'min l)) (apply 'mapcar (cons 'max l)))
Sea-Haven
Using sort x y
(setq lst (list (list 15.5 9.0) (list 11.0 9.0) (list 11.0 6.0) (list 15.5 6.0)))
(setq lst (vl-sort lst '(lambda (x y)
(cond
((= (cadr x)(cadr y))
(< (car x)(car y)))
((< (cadr x)(cadr y)))
carlos_m_gil_p
Hi guys, thanks for the help.
Greetings.
AutoCAD 2026
