Pls help me to to modify 1 program with 2
ritzofriya
Message 1 of 23
ritzofriya
Attached 2 Programs ( got it from internet only)
eww : its make a both end fillet poly line(each point manually ) (green in ss)
wa : its connect all blocks with arc(automatically).(red in ss)
is that possible wa do the connect with eww instead of arc(automatically)?
https://www.cadtutor.net/forum/topic/73579-pls-help-me-to-to-modify-1-program-with-2/
Replies (22)
Message 2 of 23
Kent1Cooper
Nothing attached.
Kent Cooper, AIA
Message 3 of 23
ritzofriya
Please Check attached link
Message 4 of 23
pbejse
Really @ritzofriya ?  Yoy think this is some sort of a treasure hunt for us?  😁
Message 5 of 23
Kent1Cooper
It "looks like" it has attachments, but:
Kent Cooper, AIA
Message 6 of 23
pbejse
@Kent1Cooper wrote:
Exactly my point, first you need to sign up if you are not a member and all those other stuff that we need to do.
@ritzofriya Why not just attach the file WA.lsp and eww.lsp here and it make it easier for us.
Message 7 of 23
hak_vz
@ritzofriya  Choose one platform (this forum, cadtutor or what ever you like) and post requests there. If you don't receive answer at one platform in two or three days, then switch to other platform.
Miljenko Hatlak
Message 8 of 23
ВeekeeCZ
Why s/he would do that? It's easier this way and faster.
Message 9 of 23
hak_vz
@ВeekeeCZIf requests are identical and if he/she can update all platforms and transfer important findings between them, then I agree it's faster. If solution is received on one platform (or seven of them) and none on other platform, post the solution and close conversation. You'll rarely see that.
Miljenko Hatlak
Message 10 of 23
ВeekeeCZ
Of course, s/he wouldn't. If s/he got what s/he came for... not motivated.
Message 11 of 23
Sea-Haven
Say no more, multi posting is a problem. Also reinforcing Kent's previous suggestion on one of the posts, 4-5 now ? A pick pick pick is the way to go.
https://www.cadtutor.net/forum/topic/73529-can-anyone-help-me-to-make-all-my-exiting-polylines-to-en...
Message 12 of 23
jrreid
I had trouble attaching files as well.
You have to go to the bottom of the postings and click the open area that says Post Reply.
Then it will start a conversation and below that is where you can attached your files.
Hope this helps.
JRR.
Message 13 of 23
ritzofriya
Thank you so much to inform me that. attached the same. kindly let me know if you are facing any issues to download.
Google drive link also available here
Message 14 of 23
ritzofriya
I'm SO sorry, my bad.
Message 15 of 23
diagodose2009
You mustr upload a sample.dwg as version Acad2007.
You save sample.dwg as old-version of Acad or ZwCad.
Message 16 of 23
ritzofriya
Dear,
Attached sample.dwg as version Acad2007  as asked
Message 17 of 23
diagodose2009
Here I upload version1.0, but encrypted,
If you like, then I can continue to,work  at your-project.
You compile the clipboard.jpg to .VLX
You compile the clipboard.jpg to Visual-Lisp
Message 18 of 23
ritzofriya
😀Thank a lot.. its perfect.  (gif attached)
If the PL corner has a fillet also.. it will be Super..(FA program attached for reference.)
Then if possible to bypass choosing option of arc or polyline each time it could be great.
Any way Thanks a looot....
Message 19 of 23
ritzofriya
Also possible to avoid crossing lines it may be great.
and keeping right angle lines.
Supporting programs attached
1.To avoid crossing (CA.lsp)
2.Right angle (lbrap.lsp)
Message 20 of 23
diagodose2009
I update the programe "pp_ritzofriya_warcplinelectrical_autoexec.lsp"
You see the file nsds.zip, you edit the OriginalSource As zip
Q=How to concatenate all pline into oneBigPline via (3.jsPline)?
The "\nCommand.com=C:Q2[enter]\n"  increase each time , increase
the value of SetColor.
   $L=(setvar "CECOLOR" (strcat "0" (itoa (dfn_color_ceinc nil (* 5 ritzofriya)))))
How to keep all'pline from (2.Pline) into one-variabile?
The hint=You set sysvardlg , always with the function "syst_mapvars"
  $L=    alo=list("Osmode","CmdEcho"),
  $L=   ptl=list(0,0),
  #L=   lvl=syst_mapvars(alo,ptl);
