Delay with VLIDE.DSK
scott_bolton
scott_bolton
Chaps,
When I open the VLIDE for the first time there is a 30 second delay between these two messages in the Trace window, even if there are no files to open.
Any idea how to make it open quicker?
S
; "C:/Program Files/Autodesk/AutoCAD 2022/vllib.dll" loaded
 <30 seconds or so>
; desktop restored from "C:/Users/sbolton/AppData/Roaming/Autodesk/AutoCAD 2022/R24.1/enu/VLIDE.DSK"
pbejse
@scott_bolton wrote:
Chaps,
I never experience that even with upgrading to 2022
Apparently you can delete the vlide.dsk and AutoCAD will recreate it. See if that helps.
Better yet. make a copy of the file first 🙂
scott_bolton
Tried that.
With no VLIDE.DSK or DAP files in the directory, VLIDE opens immediately. Once the files are created it's back to the delay.
martti.halminen
My first guess with these symptoms would be to check if you have a malware scanner checking those files every time.
